Zeroing my tach
Old Dec 26, 2001 | 10:37 AM
Wrecked82's Avatar
Wrecked82
Default Zeroing my tach
I have replaced my tach board and done away with the tach filter which was causing the problem of the tach going south. Now I need to "zero" my tach since the lack of the filter is causing a high reading. Instructions say to apply 12 v to the tach, remove needle and set at zero. I assume this means that I can just turn the ignition on to supply power and then set the needle at zero. Just checking. What I think is obvious is not always so.
Old Dec 28, 2001 | 06:33 PM
Wrecked82's Avatar
Wrecked82
Default Re: Zeroing my tach (Larry82)
That is exactly how you do it.
Thanks, Larry82. Ooops, that's me!
Old Dec 28, 2001 | 07:28 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
LMAO.
Hey that tip will work great. Thanks Larry82.
To Zeroing my tach
