strengthening the IRS
1) stronger half shafts (preferably 3 inch thick wall half shafts)
2) solid Spicer U-joints
3) have your posi case polished and hardened spider gears installed
4) install a 400+ lbs/inch rear spring and QA1 shocks to prevent excessive squatting. Squatting is one of the major issues.
5) lower the strut rod mount (special bracket available) in order to prevent camber change when rear is compressing.
those mods shift the weakest link to the axles. However, without going to Tom's setup, I don't see how you can upgrade to larger axles. Those 17 spline stock axles just won't do the job with high HP applications.
If you decide to stick with the 10-bolt and want someone else to massage it for you, I'd suggest getting in touch with GTR1999, as Gary definitely knows what he's doing. Myself, I'm a firm believer in the value of a 12-bolt IRS diff behind a stout mill, even on street tires. If Tom doesn't offer the ratio you want, try Henry's Machine Works (they heat treated my 3.55:1 gearset in house). Pepe Estrada designed the 12-bolt conversion for both companies, so either ought to do fine.
Additionally, install a solid diff locating kit and, whether you swap the stub axles out for HD's or not, I'd suggest switching to 1/2" x 3" wheel studs. FWIW, Guldstrand sells HD modified stubs, slip fitted for easy assembly and maintenance. "Blueprint" end play at .001" when you set them back up.
Oh well, seems like I will have to act like a geriatric till I get the measure of things!
The good solid u-joints and a Smart Struts kit to keep everything straight will go a long way.
JIM
BTW the 3.08 with a M21 will give you a terrible off the line gear. Even with a lot of torque the 6.77 1st gear ratio is a dog off the line. You need a M20 or a deeper set of rear gears.
528HP/563 ft lbs will be a handful...but will be fun from a 40 mph roll!
Your car is begging for a TKO or Richmond 5 speed!
JIM
JIM
I also had a few cases now shot peened by my local engine machine shop. This seems to extend the life of the GM case.
Also stop worrying - when the rear end gives up you can address it then!
Also, someone commented about using upgraded strut rods in the back. Tom's Differential sells their own brand of strut rods; they have heim joints.
This may not have 'real world relevance' but some time ago using a 'desk top dyno' I did some 1/4 mile comparisons with differing auto and manual transmissions and rear end combinations using a HO small block engine. This did not take in to account reaction times or (apparently) allow for loss of traction etc. The interesting fact was that the best 1/4 mile times were achieved with a manual c/r 4 speed with a low numerical axle ratio!
But once the tires break loose...it's much harder to hook them up with low numerical gearing. You just have to work the pedals a lot to keep wheelspin under control.
But of course there are different characteristics that everyone likes. I've had a 2.20 low with 3.36's and it ran 55 mph in 1st gear easily. And with the 27" tires it was a slug at lower speeds. When it hooked the clutch slipped a lot, so that probably saved parts.
I later had my 427 in the Vette using 3.36's and the Doug Nash/Richmond combo with a 3.27 first gear and a 1.23 4th. That was a sweet combo with a final drive of 4.13 in 4th. I revved it to the 6500+ range and it ran great.
If you're happy with the Long legs of a 2.20/3.08 combo..go for it. But you would really be impressed with some deeper gear. Gearing helps all the way through the range..not just off the line.
JIM
JIM
Good comments Jim. I just won't know untill I try it out (which should be within next two weeks with luck) The five speed with higher numerical 1st and overdrive 5th to me seems the best of both worlds, i.e more sensible for getting away and the overdrive 5th for some relaxed cruising. A few months ago I would have said the overdrive would be good for economy too - but now there is no such thing with our cost of gas.
At the end of the day the $/£/Euro cost of fuel (and the actual mpg figures) are only a number
As an aside - I use NAPA u-joints with a grease fitting now. The u-joint should fail under duress before the stub axles (inner or outer) breaks.
