1969 Vacuum Question
Old Jul 7, 2008 | 03:49 PM
Marino's Avatar
Marino
Default 1969 Vacuum Question
I have a stock 69 427/390 coupe. Just the other day, after I started it, the windshield panel opened but the wiper switch was off. When I turn off the ignition I can push the panel back down with no problems, but when I start it again, I get the same results. I am assuming I have a vacuum problem somewhere. Can anyone shed some light on this for me? Thanks in advance.
Old Jul 7, 2008 | 04:21 PM
SoCalErv's Avatar
SoCalErv
Army
Take a look at the post by member Roeich titled Vacuum System on 6/12/2008.
Same problem with solutions
Old Aug 2, 2008 | 01:33 AM
RFat16's Avatar
RFat16
I need a diagram for a 69. Every diagram i have seen shows the vacuum tank with 3 hoses. Mine only has 2. Anyone have any idea??????
Old Aug 2, 2008 | 05:48 AM
bvanpelt's Avatar
bvanpelt
RFat16: I have the same issue. I think (I'm not sure) that the vacuum diagrams are generic. Our '69s have only one vacuum relay at the headlights, and thus use only one heavy vac line to the front from the vac tank instead of two. So the tank has two lines instead of 3...
Old Aug 2, 2008 | 08:00 AM
...Roger...'s Avatar
...Roger...
Old Aug 2, 2008 | 12:37 PM
RFat16's Avatar
RFat16
thanks for the diagram that one looks like it could be the one
Old Aug 2, 2008 | 12:41 PM
Alan 71's Avatar
Alan 71
DW,
Do you happen to have the good Dr.'s diagram for 71?
Regards,
Alan
Old Aug 2, 2008 | 12:50 PM
...Roger...
Your lacking vacuum in hose #17 in the pic...the vacuum originates at the T connector D....Follow from D to hose #17--If you do have vacuum in #17 then the wiper vacuum relay diaphragm could be bad or the entire relay.
Old Aug 2, 2008 | 12:58 PM
...Roger...
Originally Posted by Alan 71
DW,
Regards,
Alan
I looked in my photobucket and I dont have it there.I had a computer meltdown awhile back and had to have a computer repair place save my documents to a disc.I will go see if I still have one by the Dr.,I'm pretty sure I have one by Zip but let me make sure its one of their corrected versions.
Old Aug 2, 2008 | 01:18 PM
...Roger...
Alan I have a 71-72 from Zip but cant seem to get it to upload from the restore disc to photobucket so I can post it.If you would like that one when my girlfriend gets home from work I can have her show me how to do it.
Old Aug 2, 2008 | 03:55 PM
Alan 71's Avatar
Alan 71
DW,
When you mention the 'corrected' version, are you referring to the location of the 'blue' hose on the headlight switch? That's the only error I know of. I would like to have a correct copy, thanks.
Regards,
Alan
Old Aug 2, 2008 | 10:33 PM
...Roger...
DW,
Regards,
Alan
Yes the blue hose but the hoses at the pulldown switch were also switched on the old diagram.I'm still working on how to get photobucket to take the diagram.It keeps saying its not a jpeg.I dont know how to change it from a pdf to a jpeg.Dang I'm stupid with computers.Why cant it be as easy as working on vacuum systems.
edit-I give up .......Alan if you pm an e-mail address I think I can send it that way otherwise we'll have to wait for a pro to tell me how to do this.
Old Apr 21, 2009 | 10:00 AM
samuel tappen's Avatar
samuel tappen
1st Gear
hello i am looking for a correct vacuum diagram for a 69 will somebody help me
To 1969 Vacuum Question
