Can Pot Metal be repaired?
Old Jul 9, 2008 | 01:43 PM
IrishJoker's Avatar
IrishJoker
Default Can Pot Metal be repaired?
On my 81 - the right side rear view mirror support has a split near the base. I understand that this support arm and mirror housing are made out of Pot Metal. Would JB Weld work to fix "POT Metal"? Or should I just look for a better used housing and support arm?
Old Jul 9, 2008 | 02:00 PM
fugawi's Avatar
fugawi
you can get it repaired. most chromers have facilities to do just that. but the quickest way would be to buy a new or used one.trywww.advancedplating.com they are my choice of platers.
Old Jul 9, 2008 | 03:43 PM
Belgian1979vette's Avatar
Belgian1979vette
It doesn't weld and even when you succeed it deforms.
Old Jul 9, 2008 | 03:47 PM
7T1vette's Avatar
7T1vette
Chances of repairing it successfully are about 1 in a 100. Replace it (salvage yard, aftermarket, or eBay).
Old Jul 9, 2008 | 03:49 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Replace the part.
Old Jul 9, 2008 | 04:20 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
I have made several repairs to pot metal pieces with no problems over the years using this stuff:
http://www.muggyweld.com/potmetal.html
Old Jul 9, 2008 | 04:23 PM
Douglas Mariani's Avatar
Douglas Mariani
GM Cert Corvette Tech
Pro Mechanic
Replace the part
Old Jul 9, 2008 | 04:40 PM
jboweriii's Avatar
jboweriii
Default advanced plating
they did my side mirror and base $150. but you get what you pay for...there workmanship is top notched.
Old Jul 9, 2008 | 05:45 PM
RHD '68 L89's Avatar
RHD '68 L89
It can be repaired but it will be cheaper and probably better in the long run to get a replacement.
Old Jul 9, 2008 | 06:01 PM
NMT1957's Avatar
NMT1957
I broke my "pot metal" dash pad support on the left side. Its a u channel that sits right up against the dash pad and the end broke off where it bolts to the body. Any one have one for sale?
Old Jul 10, 2008 | 09:56 AM
rdrunnur's Avatar
rdrunnur
Default Alumaloy
Has anyone ever tried Alumaloy?
Have seen this on TV late at night. They rebuild an Alternator mount with this stuff. All you need is a propane torch and imagination....according to them.
http://www.alumaloy.net/
Rd
To Can Pot Metal be repaired?
