Cylinder compression test
Old Jul 10, 2008 | 07:19 PM
captainmorgan's Avatar
captainmorgan
Default Cylinder compression test
I'm going to do a compression test on my engine. What is the maximum compression reading for a 1977 350 L-82 engine?
Old Jul 10, 2008 | 07:20 PM
RunningMan373's Avatar
RunningMan373
Looking at 150-175 lbs.
Old Jul 10, 2008 | 07:22 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
The important thing is that the pressures of all cylinders are fairly equal.
Old Jul 10, 2008 | 07:40 PM
captainmorgan
I got the first side done:
1- 145psi
3- 140psi
5- 140psi
7- 145psi
Old Jul 10, 2008 | 08:23 PM
captainmorgan
Second side:
2- 145psi
4- 145psi
6- 139psi
8- 139psi
Old Jul 10, 2008 | 08:35 PM
chris75stingray's Avatar
chris75stingray
those numbers look fine
Old Jul 10, 2008 | 08:44 PM
captainmorgan
cool. I wanted to check before I went through all the work of putting new heads and camshaft in.
Old Jul 10, 2008 | 08:50 PM
Jud Chapin's Avatar
Jud Chapin
Good deal!
To Cylinder compression test
