1 Headlight Relay vs 2
Old Jul 11, 2008 | 08:18 PM
jetnoise's Avatar
jetnoise
Default 1 Headlight Relay vs 2
I noticed in some of the vacuum diagrams that the 69 model uses 1 relay and later C3's use 2.
I would think GM did this for some reason or another. Anyone have a thought on this?
I am restoring 2 car right now, not C3's but they utilize the same vacuum systems as a C3. One of my cars has a single relay the other uses 2.
Since I am replacing or R&R the entire systems. I was wondering if I should convert them both to a 1 relay system or 2 relay system.
1st post
Old Jul 11, 2008 | 10:02 PM
Sayfoo's Avatar
Sayfoo
I have a 69 with 1 relay and it works fine. But, I'm thinking that the general wouldn't spend a extra cent if he didn't think it wasn't better. Now if they went from 2 to 1, that would be a different story.
Old Jul 11, 2008 | 10:24 PM
...Roger...'s Avatar
...Roger...
I think GM went to 2 to try to make the lights come up at the same time.
Old Jul 11, 2008 | 10:33 PM
PeteZO6's Avatar
PeteZO6
Interesting theory. My '69 has one relay; one headlight (the right if my memory is correct) has always come up about a tick ahead of the left. When I discovered that later models have two relays, I wondered if the General used two relays to try to bring them up together.
Cheers,
Pete
Old Jul 11, 2008 | 11:21 PM
jetnoise's Avatar
jetnoise
How do they operate on the down stroke..one at a time or simultaneously?
Old Jul 11, 2008 | 11:34 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
69 = 1 wiper relay, it is plumbed to a T going to both R&L light Assys.
I would think 1 relay may be a bit slow opening the headlights,
but ...1 relay would also open both at the same time.
I would think having 2 relays, could more easily,
give you the lazy Eye Opening.
69VETT
Old Jul 12, 2008 | 08:45 AM
Durango_Boy's Avatar
Durango_Boy
My '77 had two factory relays. I removed one, split the lines, and now run one relay for both headlights. Maybe it was my system, but now the lights go up and go down a bit more uniform.
Old Jul 12, 2008 | 09:42 AM
jnb5101's Avatar
jnb5101
i think the dual relays were done for redundancy, as most people like to have headlights at night.
Old Jul 12, 2008 | 10:02 AM
...Roger...
I think when the system is new and each bucket has the same amount of restriction(springs and things)2 relays will get closer to both buckets going up at the same time.But as they get older things change,springs get weaker and the mechanism isnt as smooth and each bucket resists differently.Personally I dont think a second of difference between the two is a big deal but some do.On occasion I have the request to make them equal.The 2 relay is easier to modify by using a restrictor in "one" of the center feed lines-on the 1 relay system you have to restrict both of the outside feed lines(red@green).6 of 1 half dozen of the other
Old Jul 12, 2008 | 11:53 AM
jetnoise's Avatar
jetnoise
...The 2 relay is easier to modify by using a restrictor in "one" of the center feed lines-on the 1 relay system you have to restrict both of the outside feed lines(red@green).6 of 1 half dozen of the other
DWncchs can you expand on this? or has it covered elsewhere on the forum?
Thanks for all the input!!
Old Jul 12, 2008 | 08:38 PM
PeteZO6's Avatar
PeteZO6
As I stated above, on my '69 with a single relay, one lags the other a tick or two opening. It's easy to tell because as they lock up, they go klunk-klunk - about as close together as when you read this. On closing, they seem to go down together, but it's not with the same "authority". They just kind of sink down quietly, with no discernible difference when they settle into place.
Cheers,
Pete
Old Jul 12, 2008 | 09:33 PM
mrvette's Avatar
mrvette
1st post
Jet, the only other cars I am aware of that use the operating headlight systems are the 68-9 GTO, and the 67 Grand Prix....
curious what you working on there.....I"m an olde tyme Pontiac man from WAY back.....
Old Jul 12, 2008 | 09:54 PM
jetnoise's Avatar
jetnoise
MRVETTE It's not a Pontiac, WISH IT WAS A GOAT
It's a 1975 Canadian made car called a Bricklin
I have some pics in my profile link
Old Jul 12, 2008 | 11:13 PM
...Roger...
All you do is restrict the vacuum to the fastest headlight.I use aquarium filter bubble rods,they are about an inch long and 5/16 diameter.I just put them inside the hose which will slow down the vacuum going to the actuator on the headlight.
Old Jul 13, 2008 | 03:21 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
Cool cars
Is that where Delorean took the design from? its almost identical to the Delorean coupes in the early 80s.
Old Jul 13, 2008 | 09:51 AM
jetnoise's Avatar
jetnoise
Originally Posted by HamadUP
Cool cars
I don't think so but they are similiar in a many ways.
jetnoise's Avatar
jetnoise
To 1 Headlight Relay vs 2
Old Jul 13, 2008 | 11:02 AM
...Roger...
I use to work on a Delorean for a guy and back in the 70s I worked for a Cadillac dealer that also sold Bricklins.Had some real nightmare stories when it came to the doors.
Old Oct 8, 2008 | 09:44 AM
TERRY CLARK's Avatar
TERRY CLARK
Would the length of hose from relay to actuator make any difference in opening speed ?
Old Oct 8, 2008 | 10:07 AM
...Roger...
I think it depends on how tight the actuator is and what kind of shape the mechanism is in.Changing the length "should" but I have tried doubling the length of the hose and couldnt see much difference thats why I went to restricting to change the speed.
