still running warm under high speeds
72, 4spd small block.
Woud like to occasionaly drive this car to work on freeways at 70 mph, so I would like it to be dependable.
Car runs at 230-235 highway and cockpit gets really warm with carpet, floor insulation. Once it reaches these temps it won't idle,stalls and is hard starting. Recent Edelbrock carb, intake, and electronic ignition.
City driving it's around 200-210. I've had original radiator rebuilt,and installed 180 tstat.
Is a secondary auxilary fan and high flow water pump the next things in the cards to cool it down?
do you have the lower spoiler in place?
are the seals around the rad?
fan clutch good?
what's your timing set at?
it could also be running lean, what do the spark plugs look like?
Those are all good questions. that I need to know. I"ll take it into to a more reputable place, that specializes in just vettes here in west Michigan, which is where I should of went from the onset, after I had carb and distributor work done. I'll ask them to look at all those thing first. Really appreciate the input, and will post what they have to say, thanks again!!
your gage and/or sender may be faulty.
Compare & Verify temps w/ known calibrated stand-alone mechanical gage.
My 71 cockpit's hot because its thin glass floors w/ no metal shielding ... & its heater core that's always got HW coursing thru it ... likely your 72 same.
Maybe starter needs a heat shield ... or replace w/ late permanent magnet starter having No temp-sensitive field coils ... like on a mid-90's GM 5.7L pu truck.
If timing and/or mixture is off ... can easily cause engine temps to skyrocket ... including exhaust & underhood/floor temps.
