Power Steering gear lash adjusting screw
1980 Corvette
All of my front end as been adjusted, fixed etc...
Alignment is excellent, new tires with new rims...
She drives hands free
Minimum problem: Bit too much "slack / play" in steering when driving.
How much slack/play ? approx /maybe 2" to 3" inches
I can drive and live it alone....
Spoke/met with another vette owner and he advised that FINE adjustment can be fixed by the top screw on top of the steering box.
Before I start playing with that screw, how sensitive is she ?
Don't want to make it worst than it is
There's a lock nut to loosen and then a simple screw to turn etc...
Any input anyone ?
Anyone experienced with that adjustment ?
Phil
Loosening the jam nut and just turning the lash adjuster screw is not the recommended way to adjust the box, and could result in some serious damage to the gears.
Have you checked the steering coupler (rag joint)? That is frequently the culprit if you have replaced all of the other steering components and still have some slop in the steering. The same link above has info on how to check it too. Thanks again to Mr. Jim Shea.
Best to elimintate all other possibilities before diving into the box.
Also, if you are checking 'slop' with the engine not running, there WILL be movement. The P/S pump has to be running to put pressure into the control valve to keep it all tight. With engine OFF, there will be free movement in the control valve.
