I am having great difficulty getting the stock throttle cable and pedal to have enough travel to fully open the secondaries on my new 950 dfm DP. With the original Quadrajet this was never a problem, it seems as though the Holley based carbs need more cable travel. Has anyone used an aftermarket pedal set-up?
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
Did you use the right cable attach point at the carb? also the check cable accelertor bracket position. lastly it may be that the cable itself has become strached over time?
Usually, there are multiple holes in the linkage plate on the side of the carb. Measure the amount of cable movement you get when you actuate the accel pedal from full closed to full open. Then actuate the throttle plate on the carb to see if there is a mounting hole on that plate which moves about that same amount [when going from closed throttle to full open]. If there isn't a mounting hole in the proper location for your accel pedal/cable, drill another in the plate where you need it.
I have tried alternative lower mounting positions for the cable on the throttle arm. Problem is by using the lowest mounting position on the throttle arm the geometry of the cable is adversely affected and the throttle arm will still not open fully. It seems as though I will just have to try and get more 'pull' on the cable at the gas pedal end of the cable. Wondered if aftermarket gas pedal assemblies would fit
If the cable is too long you can shorten the gas pedal end like in the pic with a zip tie.You can also remove the pedal assembly and in a vise bend it so you get more stroke before the pedal hits the floor.Lars recommends grabbing the gas pedal and just pulling up and bending it while still in the car-i broke the mount one time by doing it that way and havnt done it since but the mount could have already have been cracked.
Yes, I have tried this in the past and (again like you broken the bracket)
The inner/outer cable length not an issue (although I have already trimmed-back the outer sleeve) as I am using a CSR billet throttle bracket which gives a good range of adjustment (although it will have to go under a 1" drop base filter base as it won't fit won't fit under stock 2" one). I have already lost the split grommet thing in your illustration that goes on the end of the cabin-end of the cable. I didn't really want to pull out the stock pedal assy as it is a real pita getting there - but I guess its going to the only way. Thanks very much for the advise.
I'm not 100% sure if this will fix your problem. But I think the 68 pedal assembly was the same as the 69 early version which I had. Here's an excerpt from a previous post of mine where I mostly fixed the problem you are describing...
"There were two different 1969 brackets.... the early one was known to flex excessively when worn (or even when not) because the pivot was two pieces... which usually resulted in the throttle not opening all the way. (I had this same problem)
There are many "Bubba" solutions to this... to include putting a wood block underneath the early pivot point to create more travel and offset the flex in the design...
The later design had a one piece lever assembly (check out Mid America: PN-622-600) and a two piece pivot assembly (a base from Zip: PN- CZ-1071) and then a cover to secure the one piece lever). This "later" design fits the original location and typically fixes all of the pedal flex problems... I could not find the cover anywhere... but it was easy enough to make one out of a metal plate."
Its 12.45 am here in good old Blighty and I have only just had chance to look at your post. Tomorrow I will look at it in detail. And yes my gas pedal did brake and is 'Bubba'd' (or as we here say 'bodged') together. Thanks very much for detail.
I had a similar problem with my 68. Due to the extra height of my new intake, and 850 carb,I wasnt getting full throttle. I bought a universal Lokar cable and bracket and it solved my problem. Install the cable,cut it to length and you should be fine
That is another option for me - thanks
Reason: spelling
Try this--Pull up slightly by hand on the pedal to bend the arm upwards.
The pedal arm is weaker than you would think.
Over time this arm can loose some travel. If you see an improvement bend it slightly more. This worked perfectly on my 68 after I over thought it to death. Got the advise here on the forum.
Good luck!!
Good luck!!
This is exactly what I did and unfortunately it broke the bracket on the inside of the bulkhead!
There is also only two bolts holding the whole pedal assembly in place... you could just take the assembly out and do it on a workbench.... it takes about 5 minutes to get it out... however.. bending it will not fix the problem in the long run...
The fact is the two-piece 68 and early 69 pedal lever assembly was poor.. which is why they redesigned it to a one-piece lever in the later 69 models...
Which is exactly the reason why I was interested to see if anyone had replaced it with, a Lokar type set-up
The '68 gas pedal design sucks. It wears out and reduces the travel due to the 2 part design..
(Whoever came up with that design should be shot)
I replaced my gas pedal with a Lokar pedal and cable.. No more issues and fully adjustable!
I did have to lower the cable exit (where the cable goes through the firewall) in order to make it work.
Is that the one where the cable-end is actually the engine compartment side of the bulkhead? (bottom hinged organ-type pedal)
