A Warning About Edelbrock Heads
Old Jul 15, 2008 | 08:11 PM
  #61
HBZ_81_C3's Avatar
HBZ_81_C3
I have the Edelbrock Performer RPM heads (Angle Plug) and have Flowtech (Holley) headers with no problems. I use Autolite AR3924 spark plugs and Taylor wires with 90 degree boots. I have no problems other than a couple of plugs are tight to replace. I just have to use a open end wrench on the hex of the plug socket as I cant get a ratchet on the socket.
Old Jul 15, 2008 | 08:22 PM
  #62
Billysvette's Avatar
Billysvette
How old are your heads,your lucky,i was told by edelbrock that nobody makes headers for our car.
Old Jul 15, 2008 | 08:25 PM
  #63
Billysvette
71vetteracer called edelbrock to see if he got treated any better then i did ,he got the same response from them rude,and its too bad,if you guys want call them and see what response you get,they are jack asses.
Old Jul 15, 2008 | 08:51 PM
  #64
HBZ_81_C3's Avatar
HBZ_81_C3
I've had my heads about 3 months. Purchased through Summit. I ordered the headers at the same time as the heads. With the Autolite plugs and the Taylor wires it IS tight but everything clears.
Old Jul 16, 2008 | 12:07 AM
  #65
enkeivette's Avatar
enkeivette
Originally Posted by Billysvette
Sorry you dont believe it ,but its true,i have the short plugs too and you still cant get the plug in,its the angle of the spark plug hole,the number 8 pipe comes over right in front of the hole.
It can't be that much to have an exhaust shop modify that one primary tube for you. If you can't return the heads, just get it done already.
For problems, there are only solutions.
Old Jul 16, 2008 | 09:37 AM
  #66
Billysvette
I intend to,the post is for people to know not to go the root i did,and to let them know these heads are not just bolt up and go,for now until a header company starts making headers to fit our cars.
Also if i had headers that were coated ,it would be a real bitch wouldnt it.I would have to get them recoated for about $300.00 or more.So you see this thread could realy help someone else.
Old Jul 16, 2008 | 10:08 AM
  #67
BB427's Avatar
BB427
Guys i have a set of edelbrock heads (angle plug)and i have been having problems with headers.Apparently there are no headers out there that will fit our cars (corvette) SB engine.You will have to have a custom set of headers made.I called edelbrock to find out who makes a set of headers that will fit their heads and he tells me i will have to have a custom set made by kooks or lemons header makers.I am getting kinda pissed off because there is nothing in any advertisement about their heads that there are no headers being made will fit our cars.I told him that i was in a corvette club and alot of other guys are having the same problem and he told me they cant be concerned about them.
I would cancel the charge on my crediitcard and tell the company what they said that they dont care
Old Jul 16, 2008 | 10:39 AM
  #68
Billysvette
already have them and bolted up on engine,and had intake custom welded to fit heads because theres not that many intakes that work with the heads ,my fault for not real researching about the heads,but it doesnt tell nothing about the heads in any advertisments.You take for granted that they will fit everything,or at lease you think so because it doesnt tell you about that part.i guess thats my fault too.Ive really learn in todays market you need to REALLY RESEARCH about what you want to buy,dont take for granted it will fit.Its a small block chevy for gods sake
Old Jul 16, 2008 | 11:27 AM
  #69
TopGunn's Avatar
TopGunn
Don't blame yourself too much, you can only check so many things. Many companies have the philosophy that the customer is the final inspector and it's his responsibility to make sure everything is Ok before he uses the article. Makes a great excuse for management to feel good about themselves for not having screwed someone with defective or poorly engineered products by putting the blame on the customer who now has to pay for it after he's installed the item.
Thanks for posting this information on your troubles, it may be good information for someone else, hope you get things worked out OK.
Old Jul 16, 2008 | 04:18 PM
  #70
WillEE's Avatar
WillEE
I have a set of RPM HEads that I plan to use on my '82 eng. build soon. THis is good to know what I will be up against in advance. Would never have thought it could be.
Old Jul 16, 2008 | 04:28 PM
  #71
Billysvette
I hope it helps somebody else,thanks
Old Jul 16, 2008 | 04:32 PM
  #72
Billysvette
There was one guy who said he got lucky with flow tech headers,keep the thread in mine when you go to look for headers,or maybe the big header makers will start making headers for the new stuff.
Old Jul 16, 2008 | 05:21 PM
  #73
OregonVette80's Avatar
OregonVette80
On a C3 it should be "For Problems solved, there are 3 new problems that pop up!"
Old Jul 17, 2008 | 09:20 AM
  #74
Billysvette
Oh so true
Old Jul 17, 2008 | 09:38 AM
  #75
TopGunn's Avatar
TopGunn
I have FlowTech's also, when I had my ZZ4 heads with angle plugs they were perfect, no problem at all. I have only a slight issue with #4 plug boot being close with these Brodix heads.
