engine vibration cured
Old Dec 27, 2001 | 11:52 PM
Double Aught's Avatar
Double Aught
Default engine vibration cured
If you read my previous post on what I thought was a driveshaft-related vibration, it turned out to be a flexplate problem. I had the flexplate replaced and they put in a post-87, which is externally balanced. So back it went and they put in the correct one. I have upgraded to the 700r4 and it was a gigantic pain in the ****. I won't do it again. Ever.
Old Dec 28, 2001 | 08:38 AM
Matt Gruber's Avatar
Matt Gruber
Default Re: engine vibration cured (sd pacecar)
sd
it could have been worse;
the previous owner of my 72 put half the pistons in backwards!
