just finished heater core exchange
Old Dec 28, 2001 | 01:32 AM
KrAzYSnIpEr's Avatar
KrAzYSnIpEr
Default just finished heater core exchange
got my heater core today, took me 3.5 hours to do it all
not a bad job imo, i would do it again, for someone else of course
50 bux and ill do yours, haha
Old Dec 28, 2001 | 07:44 AM
BLT-71's Avatar
BLT-71
Default Re: just finished heater core exchange (KrAzYSnIpEr)
I just did mine last night, for the fourth time in 5 years. Its a breeze on a non AC vette. But as cold as it was I would have paid you the 50.
Old Dec 28, 2001 | 08:00 AM
kleitzel's Avatar
kleitzel
Hello BLT-71. Just wondering if you had to remove your dash to replace the heater core? Or could your remove/replace thru the engine compartment? My vette is a 1972 all stock 350 non AC with a 4 speed.
Also, why so many heater core replaces in such a short time?
Thanks and have a happy new year!
Old Dec 28, 2001 | 08:02 AM
terry82's Avatar
terry82
yes it did get cold last night.when i need a new core put in , i would be happy to pay 50.00 . it looks like a lot of work.
Old Dec 28, 2001 | 09:45 AM
Alwyn678's Avatar
Alwyn678
Default Re: just finished heater core exchange (terry82)
Try one with A/C and tell me how easy it is...It is one of the worst fixes on these cars by FAR :eek: :eek:
Old Dec 28, 2001 | 06:24 PM
Rockn-Roll's Avatar
Rockn-Roll
Default Re: just finished heater core exchange (kleitzel)
My opinion is that heater cores burst because the thermostat is closing and causing too much back pressure...I have never had a heater core go bad on me, and I believe it's because I don't use a thermostat. I understand that there are some thermostats that have a hole drilled in them to reduce the pressure buildup, but I've never tried them.
Old Dec 28, 2001 | 06:42 PM
ksbunting's Avatar
ksbunting
Default Re: just finished heater core exchange (Rockn-Roll)
Rockn-roll
Where does the hole get drilled in the thermostat if I wanted to try this trick that you mentioned?
Thanks and Happy New Year
Old Dec 28, 2001 | 08:05 PM
BLT-71's Avatar
BLT-71
Well I go both ways, so to speak. I still pull the dash and do most of the work that way but when I put in back in I pull the engine section to clear the tubes. It is just too tight to do it all from the engine side. And besides I needed to do a few thing under the dash.
I have been in there so many times I did it in less than an hour total time. The cold inspired me to hurry.
Me and a couple other vette buddies found that the GM replacements fail rather quickly, 1-2 year tops. The after market like Auto Zone last a bit longer either way I have replaced too many. It is scary to think my original was in there for many years.
Old Dec 28, 2001 | 08:37 PM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
Yeah, the GM cores seem to have a tendency to leak quickly. He!!, I've seen some that leaked before they were ever installed. From now on I'll have every new core pressure checked before it ever gets installed.
Old Dec 28, 2001 | 09:30 PM
KrAzYSnIpEr
Default Re: just finished heater core exchange (Alwyn678)
ya aint gunna believe me, but my car is a/c
Old Dec 28, 2001 | 10:37 PM
BLT-71's Avatar
BLT-71
I've helped a buddy with an AC car and it multiples all problems by three. More ducts bigger cases etc. I don't envy you.
But now we are ready for the chill.
Old Dec 29, 2001 | 10:43 AM
KenSny's Avatar
KenSny
Default Re: just finished heater core exchange (BLT-71)
I personally think the factory started with the heater core and then added the rest of the car...... AND I hope I never have to do it again.
Old Dec 30, 2001 | 05:46 PM
Marv's Avatar
Marv
KrAzYSnIpEr-
How much of the interior did you have to remove to do this job? Does the dash have to come out or just the console and ductwork? I know different years require different procedures and am preparing for this inevitable job on my 79 with Air. Thanks in advance for any heads up.
Marv-
Old Dec 30, 2001 | 06:15 PM
Paul L's Avatar
Paul L
Default Re: just finished heater core exchange (Marv)
This might be of some assistance.
http://www.annapolis.net/members/jul...e/HeatCore.htm
To just finished heater core exchange
