high effort power steering
Old Jul 17, 2008 | 06:04 PM
Mark Snyder's Avatar
Mark Snyder
Default high effort power steering
BBC with PS and AC but no AIR pump stuff. All factory brackets and parts. I have P255/60-16 all around. At low speed / idle I have no power steering. It is absurd to try to turn the wheel without flicking the throttle to get some power assist.
Is this normal for the larger wheels and tires or something else wrong? Adjusting the belt tension is a joke with this set up since GM hides one of the bolts on the back side of the brackets. I have about a half inch of play in each direction from center on the belt. It never squeals when I wind it out either.
Anyone else have this condition? All new parts in the steering. Once I get a little rpms up everyhting work like it should but is still high effort if the engine is idling even when I am rolling down the road.
Thanks!
Old Jul 17, 2008 | 06:06 PM
Durango_Boy's Avatar
Durango_Boy
What RPM does your engine idle at?
Old Jul 18, 2008 | 12:39 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Are you getting any noise from the system? Something obviously is not working properly.
Old Jul 18, 2008 | 07:13 AM
Matt Gruber's Avatar
Matt Gruber
u say all new parts in the steering.
i'd put the old pump back in as it may work better.
Old Jul 18, 2008 | 07:23 AM
vettfixr's Avatar
vettfixr
Did you use a new power steering pump or a rebuilt? My system had a similar problem. Once I put an AGR power steering pump on it all was well.
Old Jul 18, 2008 | 07:31 AM
Jim Shea's Avatar
Jim Shea
From your description is sounds as if you are not getting enough flow out of the pump since power assist returns when you increase your engine rpms. You mention "all new parts in the steering". Did you replace the pump with a new/rebuilt unit?
Your symptoms sounds like a worn out pump; a pump with an internal cam ring that is designed for low flow; or a discharge fitting that has too low flow.
One thing that you do NOT want to do is try and increase the pressure relief. Do not mess around with the original slider valve that is inside the pump behind the discharge fitting. Corvette valves are set for a pressure relief of 950 psi. Any more pressure and you will ruin your power steering hoses.
I would replace the pump with a rebuilt Corvette pump from a reputable supplier.
Jim
Old Jul 18, 2008 | 08:23 AM
...Roger...'s Avatar
...Roger...
Jim
Jim how about (if he still has old pump)transferring the old valve and spring and fitting(#5 and#6 and#24)to the new pump?
Old Jul 18, 2008 | 10:42 AM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
that's what I would try, is tranfering the old valve assembly.
That will give him the same pressure as his old unit. 69VETT
Old Jul 20, 2008 | 09:51 AM
Mark Snyder
Sorry for the delay in getting back to you. I bought all the hardware from years ago as a kit and it sat on a shelf. It could be the pump is incorrect - how do I check this? The system does not make any sounds and the engine idles at 850/900 rpm (big cam makes it erratic).
I was wondering if the pulley was the incorrect size? Maybe the pump is running too slow at idle?
Old Jul 20, 2008 | 09:57 AM
Jud Chapin's Avatar
Jud Chapin
If it were me, I'd replace everything that wasn't original with original parts. It sounds like you don't know what you've got.
Old Jul 20, 2008 | 11:27 AM
Jim Shea's Avatar
Jim Shea
At 850/900 engine rpms you should have plenty of flow. I would replace the pump with one that is specific for a C3 Corvette. If I remember correctly, the typical power steering pump pulley was designed so that the pump ran at about 1.25 times engine speed. So the diameter of the pump pulley should be 0.8 the size of the crankshaft pulley.
Jim
Old Jul 21, 2008 | 08:54 AM
Mark Snyder
Before I replace the pump can I confirm it is or is not correct?
Old Jul 21, 2008 | 10:13 AM
...Roger...
Has this PS ever worked correctly? Has this problem arose just after installing the pump? Does the steering feel ok with the front wheels off the ground? (could be in the steering joints)The pump could be ok and the control valve could be the problem.The easiest thing to do is switch out #5,#6 and #24 and see if that helps or hurts.If you do this I would compare both sets of 5,6 and 24 to make sure your not putting back in the same things you took out.If they ARE different then it should make some change in the steering....if it doesnt make a difference then you might have to look at the control valve next.Welcome to Corvette diagnosis.
Old Jul 21, 2008 | 10:14 AM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
Your comment about "belt tension is a joke" makes me think that something is wrong there. Is the belt tight? If you press on the belt about halfway between the pulleys with your thumb, it should deflect less than 3/16 inch. If it deflects more, that is probably your problem.
Old Jul 21, 2008 | 12:54 PM
Mark Snyder
I would have to say no it never worked at low speed. I would like to switch out the parts but I do not have them as I converted from manual to power. Can I visually inspect these parts?
Back to the belt tension. I can not seem to get it too tight. It always seems too loose to me at +/- .5". The adjustment system is the joke - maybe it is because I have A/C and the alternator is on top of it. You need three hands to get the adjustment to work. If it was loose I thought I would hear it squeal when it was slipping at low speeds or when I threw the throttle open.
When the car is in the air I can move the wheels side to side with the engine off by pushing/pulling on the tire.
Old Jul 21, 2008 | 01:17 PM
...Roger...
If you dont have the old parts you could ask at the parts place borrow them and bring them back.....somtimes it works if you know them
You could also go to the parts place and get the correct pump come home and remove the 5,6 and 24 and swap them and try them and then return the pump after putting their parts back in.
Did you swap the pitman arm when you did the changeover?
Old Jul 21, 2008 | 03:57 PM
Mark Snyder
I believe I swapped the pitman arms but it has been eight years or so...
Any way to visually inspect for the correct arm? Is there a casting number on it?
Other cars I have driven with PS and stock tires were over boosted in my opinion so imagine my surprise when I need both arms to move the wheel at idle!
To high effort power steering
Old Jul 21, 2008 | 05:25 PM
Matt Gruber
if u can turn the pulley by hand.
the belt is too loose
Old Jul 22, 2008 | 12:11 PM
Mark Snyder
I verified last night I can not turn the pulley by hand. I also checked and at idle the pulley in turning plenty fast while I am trying to turn the wheel. Sound like I have an output problem?
If the pitman arm is incorrect how can I confirm that?
Old Jul 22, 2008 | 12:15 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
your power steering pump is simply worn out. Too much fluid is bypassing the vanes for it to be effective at idle. I've experienced the same thing.
