Battery Disconnect Switch Issue......
Old Jul 20, 2008 | 08:41 AM
koni9's Avatar
koni9
Default Battery Disconnect Switch Issue......
In my attempts to find my slow drain I bought a battery disconnect switch from Corvette Central. I hooked it up inline with my negative cable. With it all snug I tried starting my car. When I crack my ignition I lose power, I can reach back and wiggle the wire and have power again? It's almost like its arcing out? I took it off and have no problems. I guess the question that I am asking is are there any success stories from these disconnect switch?
Old Jul 20, 2008 | 09:29 AM
Paul L's Avatar
Paul L
Green **** type? Sometimes they make poor contact. I prefer the blade/guillotine version.
Old Jul 20, 2008 | 09:43 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
This is the type I have and have never had a bit of trouble with it. I purchased it at Advance Auto.
Old Jul 20, 2008 | 09:50 AM
Paul L's Avatar
Paul L
I've used that type for years with no problems. Made by a company called Wirth. JC Whitney has them as well.
Old Jul 20, 2008 | 10:11 AM
koni9's Avatar
koni9
Yup, Green **** type is what I have. How much is the lever type?
Old Jul 20, 2008 | 10:13 AM
Jud Chapin's Avatar
Jud Chapin
I think I paid a little over $20 for my lever at Advance Auto.
Old Jul 20, 2008 | 11:03 AM
Duke94's Avatar
Duke94
Knife type.
Old Jul 20, 2008 | 11:41 AM
Paul L's Avatar
Paul L
Yes, they are a bargain at $20-25. Specially for people like me who don't drive a lot and the car can sit for extended periods. Here's one on my 1967.
Old Jul 20, 2008 | 11:43 AM
FB007's Avatar
FB007
All knife switches eventually fatigue spring strength, and will gain resistence over time.
Old Jul 20, 2008 | 11:46 AM
Paul L's Avatar
Paul L
No spring involved. This one has been on my former 1979 L-82 for 12 years.
Old Jul 20, 2008 | 11:59 AM
FB007's Avatar
FB007
Uh, no. See the way the ouside clips are bent? They provide tension on the blade, serving as a spring. No tension, no contact. As they age/get warm, they aneal and lose tension, ergo, loss of contact pressure resulting in added resistence. That's why knife blade type disconnect switches eventually fail on roof top A/C units, etc.
Old Jul 20, 2008 | 12:12 PM
Jud Chapin's Avatar
Jud Chapin
In reality, everything fails eventually. I have had one for several years w/o any problems and if it does fail, I'll spend another $20. Just my 2 cents.
Old Jul 20, 2008 | 12:28 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
I've had the green **** type for about 15 years - no problems either!
Old Jul 20, 2008 | 12:30 PM
koni9's Avatar
koni9
I concur with Jud.... 20 bucks aint no thang....
Old Jul 20, 2008 | 12:50 PM
Paul L's Avatar
Paul L
Four gallons of gas here .
On a more serious side, I recall a thread several years ago where a C4 sitting in a home garage experienced some form of "spontaneous" combustion. In other words, the darn thing just caught fire without a person being present. Both the car and the house were total losses.
These cars have hot circuits even with the ignition off (lighter, radio pre-sets, courtesy lights, alarm, etc.). With the very old wiring you just never know what flaws might rear their ugly heads. Be it a green **** or blade, a disconnect is cheap insurance.
Old Jul 20, 2008 | 01:08 PM
jim2527's Avatar
jim2527
Blade type for me. Works great!!!
Old Jul 20, 2008 | 01:25 PM
SCARA451's Avatar
SCARA451
I have the blade type hooked up to the positive side. This way when I disconnect it I know that there is NO POWER AT ALL going into the car. I see most people with it connected into the negative side of the battery. Does it really make a difference? I just feel safer with it disconnecting the positive side.
To Battery Disconnect Switch Issue......
Old Jul 20, 2008 | 02:45 PM
Paul L's Avatar
Paul L
That's a very good question. And people often agree to disagree.
http://forums.corvetteforum.com/show...ery+disconnect
Old Jul 20, 2008 | 06:12 PM
RMS73's Avatar
RMS73
I use the round **** type, my **** is black rather than green.
Roger
Old Jul 20, 2008 | 08:11 PM
GaryS's Avatar
GaryS
Like Pau67 and others I prefer the knife blade type. I had a green **** spin on that was a PITA - sometimes it would make great contact, others times poor contact. Nine years later my blade is still functional and has never caused a probem. I can see that the spring action of the blade type can fail after a while but, hey, I got nine years from mine so that is only $3 a year (and countin). Great insurance imo.
