383 Short block suggestions
Old Jul 20, 2008 | 10:07 PM
drpokey7's Avatar
drpokey7
Default 383 Short block suggestions
Just wondering if anyone out there had first hand experience with any of the myriad choices for a 383 short block. I was planning on doing a 383 with AFR heads, edelbrock air gap, possibly a serpentine set up, HEI tach drive, ect, for the 73. My goal for this engine is somewhere between 400-450 honest hp. 98% street driving. I know that I could take the easy way out and buy a zz383, but I feel that with a quality, well priced short block and the parts I mentioned, I could build something better for less. Thanks in advance.
Old Jul 21, 2008 | 01:12 AM
682XLR8's Avatar
682XLR8
My suggestion would be to start out with an '87 & later block so you can use a factory-style roller cam set-up. Found mine at the wrecking yard for $100, but they can be had for cheaper than that
Old Jul 21, 2008 | 10:53 AM
jackson's Avatar
jackson
... if you're going for only 450 hp street 383 ... get about '96-'99 pu/van/truck motor ... it'll have factory vortec heads in addition to roller ... vortecs will easily meet your stated goal. Keep in mind though ... on many of the later blocks, the old mechanical fuel pump mount boss is Not fully machined and is Not functional ... but, minimal machinework makes it AOK.
However, if you're planning to buy an assembled shortblock from "X" & add heads/cam/etc from "Y/Z"... I suggest against that approach ... Instead, I'd suggest you buy the complete GMPP ZZ383 motor & enjoy its best-in-industry warranty.
Old Jul 21, 2008 | 01:18 PM
LFZ's Avatar
LFZ
you can build an honest 450+hp 383 for about the price of a zz383 ($4700). Maybe more, depending on your choice of heads. You could get a decent short block made with a cast crank, forged rods, and forged pistons, set-up for a nice roller cam, air gap intake, and a good set of heads for about $5K..
I have a 383 running 480-500hp...AFR 195s, air gap intake, comp cams billet roller custom grind, and it is very streetable. Idles about 900rpms and pulls to 6k like theres no tomorrow.
Old Jul 21, 2008 | 02:08 PM
bthibodeaux's Avatar
bthibodeaux
Here is a link to M&R, a reputable vendor on ebay that sells 383 short blocks for cheaper than you can build them. The motor on the link is all forged, and is $2,100. They also have one with a cast crank that is only $1,649.
Shortcut to: http://cgi.ebay.com/ebaymotors/ALL-F...mZ150271539134
Old Jul 21, 2008 | 04:20 PM
Zoix's Avatar
Zoix
Here's what I did.
Block: 1974 (L82) 350, 4-bolt mains. Bored .030” over (4.030” Cylinder diameter) Deck Height at 7.125” from center of crank. 0.000” TDC (Head gasket thickness is piston to head clearance).
Heads: AFR 1034 - 195cc/68cc aluminum with 8032 upgrade. (0.4375” diameter rocker studs)
Crank: Eagle #435037506000 – 3.750” stroke (350 mains)
Rods: Eagle # ESP CRS6000B3D - H-beam (6.000” center of wrist pin to center of crank bore)
Pistons: SRP #J100F8-4030-5 flat top (383 cubic inch) 1.125” compression height, 64cc compression ratio.
Camshaft: Comp Cams #12-443-8 (grind #CS XR294HR-10) Valve lift – 0.540” Intake, & 0.562” Exhaust, Duration at 0.050” – 242 Intake, & 248 Exhaust, Lobe separation – 110 degrees.
Valve train: Comp Cams #885-16 lifters (hydraulic roller), & #1304-16 roller rocker arms, with #7645-16 push rods (7.850” long). With AFR rev kit installed on lifters.
Intake manifold: Dart Kool Kan.
Fuel system: 750 CFM Mighty Demon carburetor, with Edelbrock #1721 fuel pump.
Ignition: MSD – #8361 Pro-Billet Distributor (vacuum advance), with #6420 ignition control (6AL W/R), Blastor 2 coil, & Moroso #73602 Ultra 40 Race Wires.
Old Jul 22, 2008 | 11:17 AM
drpokey7's Avatar
drpokey7
Did you build the rotating assembly yourself, or did you buy a short block from a vendor?? If so, whom did you buy it from?? Thanks again.
Old Jul 22, 2008 | 11:18 AM
drpokey7's Avatar
drpokey7
Looks like a good deal if it is honestly represented.... do you, or does anyone have first hand experience with this builder. Thank you.
Old Jul 22, 2008 | 01:38 PM
LFZ's Avatar
LFZ
I bought the entire long block from Golen Engine Service. 383/500
http://www.golenengineservice.com/ht...carbureted.htm
Old Jul 22, 2008 | 02:10 PM
bthibodeaux
I do not, but their feedback looks really good. I intend to buy a short block from them. later this year.
Old Jul 22, 2008 | 02:39 PM
tigers123's Avatar
tigers123
I'm in the process of putting in the gm 383 short block, afr 195 heads, and lt4 hot cam. The reason I bought the gm is warranty. I do not want to deal with an engine builder 1500 miles away if I have an issue with the motor. I can take it to the local gm dealership if there is a problem. The gm 383 is a little more expensive short block, but everything is brand new and it comes with a forged crankshaft 1 piece rear main seal and hydraulic roller from the factory. I know some people say I can get this done cheaper at this engine builder or that engine builder, but unless they are near by and reasonably priced that is not always true. I'm also saying that what I have done is not the end all be all for anyone. It's just the way I wanted to go with mine. Maybe this will help maybe not. Your mileage may vary
Old Jul 22, 2008 | 03:38 PM
ajrothm's Avatar
ajrothm
I would be all over a ZZ383 also if it wasn't for the hypereutectic pistons in it..... I mean they will put a good steel crank, decent PM rods but then slap hyper pistons in it? I suppose they are good enough for the 425hp it comes with but.....the ZZ383 long block even has good heads(the Fast Burns) all that motor needs to make some good power is a real cam and valve springs......but its so damn expensive to buy($5300 or so), then to have to take it apart to swap cam/springs etc....You are at $6k by the time you are done for a 450-460hp motor. That was my plan after my hopes of the T&L 408" went to the ****ter.
Old Jul 22, 2008 | 08:11 PM
HBZ_81_C3's Avatar
HBZ_81_C3
I have purchased through M&R. I got a 383 all forged short block. They use late blocks with one piece rear main seals and they are factory roller cam blocks so you can go roller cam for cheap if you want. Matt is great to work with, very knowledgable and will point you in the right direction. They're stuff is first rate and meticulously assembled. I didn't purchase on E-Bay, I went direct because I had many variences (customizations) to the base package. I highly recomend M & R Engines to anyone looking for quality stuff at very good prices.
To 383 Short block suggestions
