700R4 pan leaks
Old Jul 21, 2008 | 06:06 PM
Jasonbasi3's Avatar
Jasonbasi3
5th Gear
Default 700R4 pan leaks
Hey,
I had an upgrade to my 78, a 700R4 installed. Anyway, pan gasket is leaking. I have changed the gasket once, leaking again. Any advice or secrets to this?
Jason
Old Jul 22, 2008 | 01:42 PM
SH-60B's Avatar
SH-60B
Just make sure the pan rail is not distorted from overtightening the attachment bolts on a cork gasket. Also upgrade to a neoprene gasket if you can, I think they have steel sleeves in the bolt holes to prevent distortion from overtightening. Use the proper torque on the bolts too.
