GM HO 350 330hp ?
Old Jul 23, 2008 | 08:22 PM
nomocrap's Avatar
nomocrap
Default GM HO 350 330hp ?
What parts will need to instal the Delux Ho 350 330 hp in a 1979 Corvette T10 4spd. Like Flywheel etc. and does anyone have this motor and do You like it.
Old Jul 23, 2008 | 08:49 PM
my74ls4's Avatar
my74ls4
I needed an electric fuel pump. I also upgraded the engine with the hotcam for around 6 to 7 hundred more to take the engine over 400 in hp and tq. Have GM do the upgrade and you won't regret it.
Old Jul 23, 2008 | 09:08 PM
jdmick's Avatar
jdmick
I've had one for over three years now with no problems. It's not a rocket but it's not bad and it's reliable. As far as a flywheel goes just remember it's externally balanced. The manual you get with the motor will have all the pertinent GM part numbers listed.
Old Jul 24, 2008 | 12:25 AM
MN80Vette's Avatar
MN80Vette
As jdmick said, you'll need a GM flywheel. That's no problem, but you may want to upgrade your clutch to handle the extra torque/hp. My 350 HO Deluxe has run flawlessly in my '80 for 6 years. I've never even had a drop of oil under it.
I don't know why you'd need an electric fuel pump. I'm running a Holley mechanical with no problems. I am also running the Holley 600 cfm carb but with jets 4 sizes bigger than original and a more agressive accelerator pump. (I didn't have the jet and accelerator pump problems until I put on full length headers and true dual exhaust.)
I don't know what qualifies as a "rocket", but once you get a 350 HO Deluxe tuned well with full length headers and a true dual exhaust, you can burn rubber in two gears and a chirp in a third. That's close enough to rocketry for me.
I highly recommend recommend a GMPP high torque mini starter to go with it.
The 350 HO Deluxe is by far the best upgrade I made to my '80.
Old Jul 24, 2008 | 08:10 PM
DEMITRISTYLES's Avatar
DEMITRISTYLES
From: You Can't Buy Cool, No Friggin' Way - Mississauga Ontario
I had that motor and it was fast, just not fast enough. It may be perfect for you though.
To GM HO 350 330hp ?
