My MPG is a shocking 7.6 MPG. So after checking timing and advance (both mechanical and vacuum) my son decided to pull the carb to see what kind of gasket I had underneath. And while it appears that I have the correct 4 hole gasket I was surprised to see the black marks on the driver-side secondary and in addition a black mark indicating some kind of bleed from the primary to secondary also on the driver's side.
Any one have any idea what is going on with the carb and/or why my MPG is so low. The car runs great, no black exhaust and while I have a 3:55 gear I have a 2004R trans. Alignment was just done, tire pressure ok. I'm thinking its gotta be in the carb.
Just a shot in the dark.....but I can't tell if there is any part of that intake that is supporting the gasket from underneath in the area you speak of. No support......no seal!!! Just a hunch.
Mark
Mark
Interesting...but I would think all Qjets sitting on a edelbrock performer manifold would be having the same problem. But you may be on to something.
The vacuum advance doesn't look like it's hooked up in that dottom photo.
BigBlockk
Later.....
In the third photo I drew an arrow where it connected. There is a two prong manifold tap. One went to the TH400 which is now gone, so its plugged. The other goes to the headlights and I put a tee on it so that the distributor get full manifold vacuum.
There is your bleed problem between prim and secondary-no gasket support between them.
I'm using a Felpro 1/4 inch gasket.
Fel Pro #375-1905
(from Jegs)
Insulator Gasket, 1/4" Thick, 4 Hole
Fits Holley Spread Bore, Rochester Quadrajet, Most Carter Thermoquad's
So what kind of gasket should I use? The Felpro is fiber, if I use a different material, they are thicker. Not sure how much clearance I have. Any suggestions on a gasket. And more importantly, do you think this is causing the poor MPG?
Fel Pro #375-1905
(from Jegs)
Thanks for everyones help!!!!!!!
Fits yes but not so sure if its a good match.You could add a 4 hole plate so each bore would seal up.(Matt Gruber talked about this.)
On your issues and questions:
First, there is nothing wrong with the slight black sooting on the bottom of the carb - that's completely normal, and is not indicative of any problem.
Your base gasket should be the standard, stock, 1/4" thick open plenum gasket. The 4-hole thin gasket you're using is not causing any problem, but it's not correct, and does not work well. Use the stock 1971-1981 thick open gasket.
Poor fuel economy can be the result of a multitude of factors, and cannot be solved via e-mail or forum discussions. If timing is correct, best thing to do is to do a complete carb teardown and check its jetting specs against the correct specs for the carb. Then correct any problems with the carb (there can be dozens), set float level to .375" and do a precise blueprint setup of the carb back to spec.
Lars
Thanks Lars. I didn't realize I had the wrong base gasket on there. I just read your paper on Q-Jet overhaul and I'm taking your advice and pulling the carb for a complete overhaul. Your paper already help me realize I have the wrong secondary rods (DA and one if them is bent). In the meantime I found a new Edelbrock 1901 and I put that on until I have time to correctly have the original carb professionally rebuilt. Thanks for everyone's help and suggestions. Hopefully I'll get my MPG above 8.
