Hi folks: I finaly got my engine light bulb working. I ran a diagnostic using the paper clip trick and found the ecm to be working properly. However, I received to error codes. It first flashes 3 times then flashes 4 times then the cycle repeats itself. According to my chart I think it is a O2 sensor and a coolant temp sensor. Could andone advise if this is right or what the these error codes mean. thanks
I wouldnt assume the codes are identical between 81 to 82. Better look up the codes for the 81. The GM Helms shop manual should help or even an internet search might turn up something.
