How do I stop the squeal?
Old Jul 28, 2008 | 08:30 AM
cargo247's Avatar
cargo247
Default How do I stop the squeal?
New brakes everything new and I drive down the road and I sound
like a dump truck coming to a stop how do I get rid of this?
Todd
Old Jul 28, 2008 | 08:34 AM
Durango_Boy's Avatar
Durango_Boy
Todd
Is it one particular wheel or all of them? What brand pads did you buy? Some harder pads tend to make more noise. I know this sounds bad, but did you happen to get one or more of the pads in backwards? It's possible to do and it makes noise like you're describing.
Old Jul 28, 2008 | 09:46 AM
cargo247's Avatar
cargo247
Hey DB
no the pads are in right and the pads a raybestos and they are all making noise
Old Jul 28, 2008 | 11:37 AM
GaryS's Avatar
GaryS
I had similar squeeling on another non-Corvette car and I solved the problem by taking the pads out and using my bench grinder to bevel the leading and trailing edge of the pads. Completely stopped my noise. Fwiw, I used about a 30 degree angle, or so.
Old Jul 28, 2008 | 11:41 AM
Durango_Boy
That was my next suggestion. Remove the pads and bevel the leading edges with a grinder or file, and clean everything up with brake cleaner before re-installing.
Old Jul 28, 2008 | 11:49 AM
cargo247's Avatar
cargo247
They came with bevelled edges and a grove down the center of the pad
Old Jul 28, 2008 | 11:51 AM
Durango_Boy
Do they make noise when driving and braking or just when you're braking?
Old Jul 28, 2008 | 12:04 PM
Green76's Avatar
Green76
Todd
Go to the auto parts store and buy a set of "organic" brake pads for the front and rear, you won't need to do anything to them, they work right out of the box.... (They are cheap also).
I had the same problem I was using semi-metallic, my vette sounded like a freight train stopping........
I would be careful about sanding or grinding on brake pads, the dust can be very dangerous to breathe, I'm not 100% sure all the asbestos is gone in them.
Ulf
Old Jul 28, 2008 | 12:40 PM
cargo247's Avatar
cargo247
one wheel when i am driving very little only hear it when i drive by a fence and all of them when i come to a stop sign and only after the get hot???
Old Jul 28, 2008 | 12:42 PM
cargo247's Avatar
cargo247
anyone tried of this stuff to help with the noise
http://www.k2distributing.com/pages/...e-specials.php
Old Jul 28, 2008 | 02:02 PM
7T1vette's Avatar
7T1vette
DO NOT spray anything like "anti-squeal" stuff on your rotors and/or pads. You will just contaminate them. Did you put anything on the back side (metal substrate) of the new brake pads? Every auto parts store has little packets of silicone goop that you spread on the back of the brake pads. Once that stuff starts to set up, install the pads. That goop will dampen any vibrations set up in the brake pads and keep it from transmitting to the car's frame. [I'm amazed that the parts place didn't offer that to you when you bought the pads.]
Old Jul 28, 2008 | 02:26 PM
cargo247's Avatar
cargo247
i did put that goop on and it still did nothing how long before the pads seat them selfs maybe thats all i need to do is put a few hundred miles on it with my foot on the brakes you dont think the spray would help?
what about these
http://www.parts123.com/parts123/yb....Z5Z5Z50000050G
anyone use them ?
Old Jul 28, 2008 | 11:12 PM
jbaron's Avatar
jbaron
2017 C3 of the Year Finalist
I tried those .... didn't help at all. I'd like to know what works too.
Old Jul 28, 2008 | 11:44 PM
Green76's Avatar
Green76
Hey guys, like I said earlier...
Total cost for all four wheels about $30.00
I have tried all kinds of stuff, the bottom line is, it doesn't work......
Organic brake pads work great for your street driven vette, it will stop just as fast as some of the fancy metallic brake pads, another benefit is that the organic pads are easy on the rotors, won't ruin the rotors like some of the harder metallic pads do....
If you are road racing or auto crossing, then I won't rcomend using organic pads, they will fade if they get really hot...........
Old Jul 29, 2008 | 08:57 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Try a couple of runs up to 40-50 mph and stand on them that may help them seat and interface better.
Old Jul 29, 2008 | 09:30 AM
Brooklinite's Avatar
Brooklinite
Years ago I had new brakes all around on my '77 and it squealed like a stuck pig for a while. It eventually stopped.
To How do I stop the squeal?
