Will 2 head gaskets lower compression
The reason it's pinging right now is mismatched parts, cam too small for compression. Put in a bigger cam, problem solved
"If" it were a small block and you were at 10.5:1 with that cam you are 8.5 DCR which will ping.
"If" it were a small block and you went up one cam you would be at 8.17DCR which should be OK on 93 octane
Last edited by moosie982; Jul 30, 2008 at 10:32 AM. Reason: clarification for some comedians
Ralph.
limit the advance by weight travel:
stop pin & curve(stronger springs)
it will not be doggy if tuned right
will fry tires & not ping
Two head gaskets would be so weak. I'm replacing a quality head gasket without the overpressure of one detonation.
I've built two motors with to small of cams and had to lower my dynamic compression ratio. bigger cam doesn't mean radical idle if you put some thought into it. Don't use or trust some $8 per "Techy" at CC.
Before I would tear everything apart maybe try retarding the cam 4 degrees.
"Read" your spark plugs. The wrong heat range plug can cause detonation as well as preignition. If the insulators around the electrodes on your plugs appear yellowish or blistered, they may be too hot for the application. Try the next heat range colder spark plug. Copper core spark plugs generally have a broader heat range than ordinary plugs, which lessens the danger of detonation.
Check for engine overheating. A hot engine is more likely to suffer spark knock than one which runs at normal temperature. Overheating can be caused by a low coolant level, a slipping fan clutch, too small a fan, too hot a thermostat, a bad water pump, or even a missing fan shroud. Poor heat conduction in the head and water jackets can be caused by a or steam pockets (which can result from trapped air pockets).
Check for a lean fuel mixture. Rich fuel mixtures resist detonation while lean ones do not. Air leaks in vacuum lines, intake manifold gaskets, carburetor gaskets can all admit extra air into the engine and lean out the fuel mixture. Lean mixtures can also be caused by dirty fuel injectors, carburetor jets clogged with fuel deposits or dirt, a restricted fuel filter or a weak fuel pump.
If the fuel mixture becomes too lean, "lean misfire" may occur as the load on the engine increases. This can cause a hesitation, stumble and/or rough idle problem as well.
The air/fuel ratio can also be affected by changes in altitude. As you go up in elevation, the air becomes less dense.
A carburetor that's calibrated for high altitude driving will run too lean if driven at a lower elevation.
The 425 horse dual quad 409 motor cam from the factory with double stacked head gaskets ,,,,,,, you are quite right
geo
My first cam was an XS282S. It was a good cam but I wanted something a little bigger with my aluminum headed 454. I went with a custom ground ISKY solid 617\629 250 degrees at .050. Lobe center was ground at 108 and I installed it 4 degrees advanced. I have tons of low end torque and this cam actualy idles at 8-900 rpms where the XS282 I was lucky to be at 1050.
427HotRod helped me and tshort pick this cam that is based on a circle track design to move the torque down in the lower rpm range. I am very happy with it!!!
Wade
Wade
