vacuume secondaries not working
The original carb was a holley 780 so I feel the CFM is correct. It had a
670 from years ago and I wanted to change.
The problem is there is no 4 barrell sound when I run the car hard.
I have installed the lighter YELLOW spring but I still do not get full opening.
I just tried a test where I used a paper clip attached to the vacuume rod and then drove the car.
I then ran it up thru 6000 RPM in 3rd gear and then looked at the clip.
It had only moved 1/4"
But full opening of the throttle moves the rod 3/4"
Any suggestions on why the secondaries are not opening but 1/3 of the way?
David
Lars
I never run it that hard.
There are no modificatiosn to the motor. It just had a 670 that was installed years ago and I wanted to install a carb. closer to the original factory CFM.
Chevrolet installed a 780cfm so I do not think a 770 is too much.
David
He has a Holley - there are no "top" and "bottom" butterflies, and the throttle linkage does not open the secondaries on a Holley vac sec. The secondary throttle is opened by venturi vacuum from the primary side acting against diaphragm spring pressure on the secondary throttle shaft.
Lars
Thanks for the input. 1st. glad to hear from you and hope you are well
I will look into the white spring
David
Thanks for the kind words. -
Keep in mind that GM was into the marketing thing... just because they put a 780 on the engine doesn't mean the engine was capably of taking full advantage of it. By using a vac sec carb, you can install a slightly over-sized carb without any performance or drivability penalty, yet get the "bragging rights" to the big "performance" carb. And GM did do this in their ads on that engine...
The 770 will run just great on your 350, but you may never see the vac secs fully open below 6500 rpm. The white spring should help out, but make sure you don't get a bog going into the secondaries with it.
A personal observation on this issue: I had a friend's 427 Vette on a chassis dyno with a vac sec 750 carb. With the thing at WOT and screaming at 5700 rpm, the secondaries were only about 1/2 open with the white spring. By manually forcing the secondaries wide open, we picked up 20 hp... After that, I installed an 850 mech sec carb on the engine and produced the best hp rating...
First clear your throat and go WHOOAAAAH!!! until you let off the go pedal
With a little practice you can even add tire chirps on the shifts.
Sorry, I can't sleep tonight.
do a simple google search on carb forumula and that same formula comes up over and over again.
from what i understand VE is normally 80-85%
so (350Xsay 6000 rpms)/3456*.85=516cfm carb
LArs , I understand your point on the marketing angle from GM. I can report that on low end performance the cars does run better.
I have purchased the spring set today and will try it tonight..
Just a FYI , I called Holley and your's and their advice are the same.
The forum is lucky to have you.
David
I am going to follow the advice my mother gave me years ago and not say anything here.
David
Thanks Baxon
The Holley charts do show 770 as correct on a 350 @ 6500 RPM.
But the formula you site does diasgree with that.
I think Lars has me on a good path to a little better top end and then I will just need to accept what I have or put the 670 back on.
The bottom end performance with the 770's #72 jets over the older #65 primary jets on the 670 have made a big difference from a standing take off.
Thanks again
David
I installed the white spring and test drove the car.
There seemed to be a definite improvement in performance.
It also clearly seemed louder than yesterday.
The paper clip test showed 7/16" movement. This up from the 1/4" yesterday.
So 3/16" more travel or about. 75%
There was also no dead spots or bogging down.
Thanks for the advice. I guess I learned this lesson the hard way.
David
