Suggestions for engine bay paint
Old Jul 30, 2008 | 07:18 PM
79Cruzer's Avatar
79Cruzer
Default Suggestions for engine bay paint
As I start cleaning up the engine bay on the 'new' '75 project I'm wondering which black paint I should use. I'm leaning toward a black gloss versus flat black. Any suggestions for paint type/brand?
Old Jul 30, 2008 | 07:57 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
I used Duplicolor Semi-gloss black. Wasn't as shiny as gloss black but semi-gloss gives it a nice sheen.
Old Jul 30, 2008 | 08:32 PM
7T1vette's Avatar
7T1vette
Gloss black paint in an engine bay looks "cheesy", IMO. Factory paint is nearest a semi-flat black. Semi-gloss black paint looks pretty close. Flat black is a NO-NO as it is impossible to keep clean. Krylon used to make a semi-flat black but recent feedback is that Krylon has gone to water-based paints and no longer makes it. If you have your own spray equipment, you can use gloss black and add a de-glosser to get the sheen you want.
Old Jul 30, 2008 | 08:41 PM
shark food's Avatar
shark food
Use John Deere Blitz Black. It is available at any John Deere Store. It is as close to the original as you will come and it sprays out nice
Old Jul 30, 2008 | 08:58 PM
71rdster's Avatar
71rdster
Someone on the forum has a nice yellow spatter paint job over semigloss black that looks pretty good. Mine is Candy Brick red over black with a blue pearl top coat. What effect are you looking for?
Old Jul 30, 2008 | 09:14 PM
Scott Marzahl's Avatar
Scott Marzahl
Semi flat Rustoleum 777.
Old Jul 30, 2008 | 11:00 PM
79Cruzer's Avatar
79Cruzer
Thanks for the good suggestions. I'll try a semi-gloss on 1-2 areas of the engine bay withe a few different paint types then decide. Thanks for the help. This is one the great benefits of this forum.
Old Jul 30, 2008 | 11:09 PM
79Cruzer's Avatar
79Cruzer
Looking for something decent (black) without too much sheen!. It sounds like the semi-gloss is the best bet for what I'm looking for. I want the engine bay to look like it was new but not all 'dolled up' and flashy as it's not going to be a show car, but a working man's pride and joy that will be driven and not bashfull to raise the hood to show off sometimes!
Old Jul 30, 2008 | 11:10 PM
b71vette's Avatar
b71vette
I used Krylon Fusion for Plastics Satin Black, bought mine at Wally World. Painted 2+ years ago, so far no problems.
http://www.krylon.com/products/fusion_for_plastic/
Old Jul 30, 2008 | 11:22 PM
gve's Avatar
gve
Use the John Deere it has the best mar resistance of all the other blacks, I bought the other blacks and sprayed them out and tested
Old Jul 30, 2008 | 11:51 PM
Blain's Avatar
Blain
Just did my engine compartment, windsheild frame and inside the nose area. I recommend SEM HR010 Hot Rod Black Kit. Catalyzed urethane, I think. Impervious to brake fluid, anti-freeze etc. Can't trust what comes from a rattle can.
www.semproducts.com
Anyway it is a satin look, not glossy. Went on well with an HVLP touch up gun.
Not good pictures to demonstrate the finish.
Blain
Old Jul 30, 2008 | 11:52 PM
Dantana's Avatar
Dantana
Don't mean to hi jack but curious how you all cleaned your engine bays for paint? I've got some serious cracking in the paint up on the firewall and, short of a wire brush and a lot of elbow grease I have no idea how to get it down to a paintable surface.
Any tips would be appreciated. Thanks.
Old Jul 31, 2008 | 07:21 AM
koni9's Avatar
koni9
Krylon all the way. The good stuff is hard to find(Semi Gloss or Semi Flat I forget) They have changed over to this new fusion stuff and I am not a fan.
Old Jul 31, 2008 | 07:32 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
This is what I use on all black parts, including the frame, and engine bay areas on the Vettes I've worked on. It always turns out great and looks original.
Old Jul 31, 2008 | 07:38 AM
lvrpool32's Avatar
lvrpool32
I dont know in other locations, but the good old Krylon semi flat black is alive and well in New York, just with a revised can and spray nozzle, same formula, good covergae, dry in 10 minutes and still only $3.50.
If you want a really good satin black, then Spies-Hecker make a 2 part rally black, its relatively expensive ($60 a quart plus hardener) but it covers well and will not be affected by gas,brake fluid etc like the solvent based paint will.
Nick
Old Jul 31, 2008 | 07:46 AM
BarryK's Avatar
BarryK
Personally, I like the SEM #39143 Trim Black paint.
here an example, the inner fenders, while i was doing my engine bay 2 years ago:
Before:
After:
Old Jul 31, 2008 | 10:26 AM
monza_man's Avatar
monza_man
Subscribed (I'm getting ready to do mine soon too)
Old Jul 31, 2008 | 01:12 PM
tmacb's Avatar
tmacb
Personally I don't like this look. It went out of style in the early 90's. IMO a nice semi-gloss or semi-flat is best unless you are going for a really show car oriented look, in which case body color base/clear with as much smoothing and decluttering as possible is the cleanest look.
Old Jul 31, 2008 | 02:08 PM
mudbone64's Avatar
mudbone64
From: I'd like to propose a toast... to internal combustion and wind in the face.
On this engine compartment I used rustoleum semi-gloos black for the metal parts and some sort of satin black (can't remember the brand) on the non-metal parts.
To Suggestions for engine bay paint
