Torque Setting for Harmonic Balancer
Old Dec 30, 2001 | 03:09 PM
mrbeaubo's Avatar
mrbeaubo
Default Torque Setting for Harmonic Balancer
What is the torque setting for a harmonic balancer in a 350?
Old Dec 30, 2001 | 03:16 PM
Jvette73's Avatar
Jvette73
Default Re: Torque Setting for Harmonic Balancer (mrbeaubo)
Crankshaft bolt on a 350 is 60ft/lbs
Old Dec 30, 2001 | 03:20 PM
mrbeaubo's Avatar
mrbeaubo
Default Re: Torque Setting for Harmonic Balancer (Jvette73)
Thanks.
Old Dec 30, 2001 | 04:42 PM
Techno's Avatar
Techno
The damper is pressed on. So you shoudn't stop till it bottoms.
Old Dec 30, 2001 | 05:38 PM
mrvette's Avatar
mrvette
Default Re: Torque Setting for Harmonic Balancer (Techno)
Don't learn the hard way like I did, that bolt is NOT for PRESSING on that damnper......I am used to doing Pontiac engines that way, the early one's...and not SBC's.....I tried it on my engine here and had to redo the threads in the crank....need a fully threaded press/tool into the snout in order to press that balancer on....in fact my engine is held with alotsa locktite and minumum torque as I no longer trust the threads....been fine for 4 some years now....
GENE
To Torque Setting for Harmonic Balancer
