Power Brake Booster question
I project to replace my non Power Brake system with a Power Brake system. Steal i bought the MasterCylinder (wich is not the same) and now i have to buy the Brake Booster.
I just want to know if there is a difference beetwen the "push rod" on a non power brake and a Power Brake at the end of the brake pedal.
If i keep my "push rod" from my non Power Brake, do you think it will fit; or i should buy a specific one? thank you for your help...
You won't need to reuse that rod. The new booster has it's own threaded pedal rod, and the clevis threads onto it like your current one. You will pin that clevis to the lower hole on the pedal.
You will also have to modify your firewall to accept the four stud power booster, instead of the 2 stud stock manual master.
this is exactly what i expected. Sorry but when you say i have to modify the Firewall, what do you mean by modify. I saw 4 bolts on my firewall. I have to cut the firewall??
For information, my car is C3 from 1975
Thank for your answers
Can you take and post a picture of your firewall and stock master?
Your stock master should have two studs coming out of the firewall. The new booster that goes in it's place at the firewall will have four studs, and a main body hole centered in the four studs. Your stock master has the body hole between the two. Converting usually means that you need to drill a new body hole lower down, and drilling to new stud holes for the extra two studs.
I just may be wrong about your year though so pictures would help a lot.
