mirrors - too loose
Old Aug 8, 2008 | 08:56 AM
wolf01's Avatar
wolf01
Default mirrors - too loose
anyway to tighten up the mirrors? I have a 75 t-top. I have had the top molding off, but does not appear anyway to tighten ball socket on rearview. also the side mirrors ball socket loose as well, when I hit 70 the mirrors sort of folder down. Do I just have to go new? and if so anyone offer a preference on vendors and quality, there are so many to choose from.
Old Aug 8, 2008 | 10:22 AM
smon's Avatar
smon
Im having the same problem, maybe its because i bought my mirror off ebay...
I thought about just gluing the mirror in place since im the only one who drives the car.
Maybe someone here has a better solution
Sean
Old Aug 8, 2008 | 10:39 AM
Wrencher's Avatar
Wrencher
Default Very common..
Mine are the same way, and buying new ones doesn't always solve the problem. Many here on the forum have complained that the replacements were barely better than the old ones.
There was a post a long time ago (years) that had a fix for the existing mirrors. It involved soaking the mirror in gasoline overnight, which released the glass. Then the riveted/screwed in (can't remember which) strap was removed and a nylon washer installed on the pivot ball under the strap to tighten it up. re-attach the strap and glue the glass back in and your done.
I keep putting this off, and I haven't figured out a safe way to soak the mirror, but it's on my list!
Hans
Old Aug 8, 2008 | 10:44 AM
weez58's Avatar
weez58
check here:
http://forums.corvetteforum.com/show...t=loose+mirror
If you do a search you'll find several posts. Search: loose mirror
Regards,
Bob
Old Aug 8, 2008 | 11:06 PM
gbvette62's Avatar
gbvette62
It's a common problem, it doesn't matter if they're GM, us repros or the taiwan ones. The original ones suffered this problem, the US repros are made by Paragon from original GM modes, and have had this problem and the overseas ones sold by alot of vendors ($45.00 to 59.00 w/mount) haven't been around long enough to know if they're better.
If you belong to the NCRS, the current issue has an article about how to take these apart and tightening them up.
I was at Thunderbolt raceway, the new road course in NJ today for the vintage race. I had to laugh at all the VetTe racing that had original type mirrors. They all had "racers tape" on the mirrors to hold them in position!
Old Aug 9, 2008 | 05:08 AM
RunningMan373's Avatar
RunningMan373
this is what's inside. '73 stock mirror.
Old Aug 9, 2008 | 05:42 AM
74Blackfoot's Avatar
74Blackfoot
Super glue fixes side mirrors. Just put a little on the ball and move the mirror all around before it hardens. Get in the car, shut the door and move it into position and get out of the car without opening or closing the door, bumping or jarring the mirror.
Old Aug 9, 2008 | 07:56 AM
Matt Gruber's Avatar
Matt Gruber
go to FLAPS and buy better side mirrors, less than $20
ended problems in 1990. thank goodness for FLAPS etc.
bet u don't know who flaps is
Old Aug 9, 2008 | 09:32 AM
AimHigh's Avatar
AimHigh
worked for me!
Old Aug 9, 2008 | 10:40 PM
Red 71's Avatar
Red 71
From: Melbourne, Fla. 6 months- New Middletown, Ohio 6 months
Just fixed my inside rearview mirror on my 71 today. What I did was to take out the little plate that holds the ball socket in place and put it in a vise to flatten it slightly. Now when I reinstalled the two little fingers into the bracket in the headpiece there is a little gap that the screw must now compress. Doesn't take much flattening to give more grip. Do not try to flatten the ball socket portion of the clamp, just the overall curvature of the clamp.
To mirrors - too loose
