Compression in lbs per sq in?
Old Aug 9, 2008 | 01:29 PM
dfolse62's Avatar
dfolse62
Default Compression in lbs per sq in?
Recently rebuilt engine. 400 CI. I am not sure of the final compression ratio, but the engine sort of sounds like a diesel, just more noise than I like. I don't know what to check next. I did run a compression check this morning. On one older gauge (holding it in by hand) it showed to be about 132. With a gauge with better rubber (still holding in by hand), it showed at just over 140 lbs! Is this high? Thanks!!
Old Aug 9, 2008 | 02:24 PM
Retro78's Avatar
Retro78
Without knowing more about your engine build, the actual number is meaningless. But no that is not too high. Measure all 8 cylinders and look for differences between them.
Old Aug 9, 2008 | 06:20 PM
billla's Avatar
billla
St. Jude Donor '14
Let's back up for a second - it's clattering like a diesel, even at idle?? First thing that comes to my mind is valve adjustment!
Old Aug 9, 2008 | 07:00 PM
dfolse62's Avatar
dfolse62
I'm sorry I can't give more details until tomorrow. It is a bored out 400. Flat top pistons with eyebrows for valve clearance, 486X heads. New Comp cam and lifters. Hydraulic. The valves were set before initial crank up. I then set them while running. No noise here. It seems to be more internal. I will know more tomorrow as a motor builder is looking at it. I don't know if it is pre ignition, piston skirt slap, or what. It just sounds like crap. Runs good!! Just sounds like a John Deere. Make that an International Harvester hay baler.
Old Aug 9, 2008 | 07:10 PM
billla's Avatar
billla
St. Jude Donor '14
Good luck - not enough there for a guess, but I'm sure your shop will sort it out.
Old Aug 9, 2008 | 10:33 PM
howarsc's Avatar
howarsc
I have run motors with .006-.010" piston to bore clearance and made a diesel like sound, especially at idle. Piston rocking.
To Compression in lbs per sq in?
