1980 power door lock failure
Old Aug 10, 2008 | 09:53 AM
Randy2red's Avatar
Randy2red
Default 1980 power door lock failure
My 1980 power door locks never worked since purchase,no sound nothing. Power windows work fine.I can not find a blown fuse. What should I take apart first to troubleshoot.Thank You
Old Aug 10, 2008 | 10:44 AM
...Roger...'s Avatar
...Roger...
The switches are usually the culprit.In my shop I have a used good set of switches I always put in to rule out the switches and it works most of the time.Here is a diagram of the system.
Old Aug 13, 2008 | 01:46 PM
Sean82's Avatar
Sean82
if both locks do not work then the passenger side is not grounded.
look closley at the diagram above.
typicaly the pass side causes all the power door lock problems.
Old Aug 13, 2008 | 02:09 PM
CarEngnrd's Avatar
CarEngnrd
3rd Gear
I have run into this problem twice (both were 1980) on cars that have been sitting for a number of years. Do the locks easily operate manually with the *****? If not the linkages and rockers could have corroded and the lock motors do not have enough power to over come it. I had one that was so corroded that I had to take the assembly out of the door to get it broke loose with muscle and penetrating oil being careful not to bend everything up.
To 1980 power door lock failure
