Hydrolic Clutch Benifits??
Old Aug 11, 2008 | 08:56 PM
GrtDanes's Avatar
GrtDanes
Default Hydrolic Clutch Benifits??
Hi guys
What are the benifits of going to a hydrolic clutch compaired to the mechanical??Is it worth the almost $700.00 they ask for??Im thinking of going with Keisler TKO600.Any info is appreciated.
Doug
Old Aug 11, 2008 | 09:09 PM
Binnie77's Avatar
Binnie77
Originally Posted by GrtDanes
Hi guys
Doug
I am running Keisler's hydraulic release bearing and it is a switch from manual linkage that I certainly do not regret. It sure makes for a clean setup and does away with all the linkage and rods. Lots more room under there to work without the linkage. The clutch effort will be at least half of what it is with manual linkage. I highly recommend it and the install is pretty straight forward, their instructions are very good.
Old Aug 11, 2008 | 09:34 PM
GrtDanes's Avatar
GrtDanes
Thanks Binnie 77 will give it some thought.
Old Aug 11, 2008 | 11:05 PM
gkull's Avatar
gkull
I vote for manual and the Centerforce DFX clutch/PP with 20 pound or less fly wheel behind a 600 with the .82 OD.
I drive mine around and it has less foot pressure than my ford 4X4
Old Aug 12, 2008 | 05:26 AM
JustinD's Avatar
JustinD
I put mine together from 85 1 ton gmc parts. Pretty nice, I had tons of issues with the stock style setup when I swapped to a 4 speed. For $100 and some fab work I wish I would have done it from the get go.
Old Aug 12, 2008 | 06:57 AM
theandies's Avatar
theandies
Question:
Do you have to pull the trans to install it? In other words does it change the throwout bearing and clutch fork or does the kit work with those? My wife has expressed interest in driving the Vette but can't push the clutch pedal in very well because of the force it takes.
Old Aug 12, 2008 | 07:41 AM
Binnie77's Avatar
Binnie77
Originally Posted by theandies
Question:
The kit that Keisler sells is unique and is designed for the TKO only as the hydraulic release assembly replaces the front transmission flange.
Old Aug 12, 2008 | 03:54 PM
rj8806's Avatar
rj8806
Binnie pretty much summed it up...thank you sir.
Our hydraulic kit uses an internal hydraulic throw out bearing which is mounted to the front of the TKO. It does away with the Z-bar and all of the mechanical linkage and does make for a clean looking engine compartment. On the other hand, if you are used to and like, mechanical linkage, hydraulics will feel strange to you. Personaly, I like the "feel" I get from mechanical linkage. I can feel the clutch when engaging and dis-engaging. With hydraulics, the fluid dampens that and you lose the "feel".
Typically, hydraulics will give you the best "bang for the buck" if you have a high horsepower motor that requires a heavy clutch. In that instance, hydraulics makes it easy to push the clutch down. On standard horse power applications (300hp-450hp), the diaphram style clutch already has a light pedal effort, so in my opinion, hydraulics is not needed nor is it as beneficial. The previous statement was a personal statement and not necessarily the Keisler standpoint. To each his own. Obviously if you have had surgery on your knees, legs or back or are just not as strong as you used to be, then hydraulics will benefit you as well.
Richard
Tech Support
Old Aug 12, 2008 | 08:25 PM
GrtDanes's Avatar
GrtDanes
Thanks every1 for the input..Think im going 2 stay mechanical..I still have a couple yrs left in my leg.lol
Old Aug 13, 2008 | 10:54 AM
blnvette's Avatar
blnvette
I have a new 08 Zo6 with a hydraulic clutch and a 73 coupe with a mechanical clutch. I hate the feel of the Z06's clutch compared to the mechanical in the 73.
Old Aug 13, 2008 | 02:22 PM
WillEE's Avatar
WillEE
I considered both and decided to put Keisler's TKO 600 w/Mech. clutch in my '68 Camaro and after 2 years have no regrets. Nice feel and not too hard pedal effort. Definitely more effort required than hydraulic but huge improvement over the effort that was required back in the muscle car day. It gives me the feeling that my foot is in total harmony w/what clutch is doing. I'm not sure how significant of an issue this really is but one factor that weighed in my decision was that sometimes the car will sit for a couple weeks to a month w/o driving it and several people I spoke to had concerns about seals drying and the fluid leaking in these scenarios where a car sits periodically vs. routinely driven and as a result presents more risk of wrecking your clutch disc surfaces.
To Hydrolic Clutch Benifits??
