oil pan gasket
Old Aug 11, 2008 | 12:57 PM
jnb5101's Avatar
jnb5101
Default oil pan gasket
there's another thread now about changing the oil pan on a sb. i didn't want to hijack, so-i remember reading about two different thicknesses of gaskets. am i loosing my mind or are there? (feel free to answer both questions) if so, how do you determine which to use?
jeff
Old Aug 11, 2008 | 01:06 PM
Vette79C3's Avatar
Vette79C3
Just get a fel pro 1 piece rubber oil pan gasket. Works great.
Old Aug 11, 2008 | 01:38 PM
SH-60B's Avatar
SH-60B
jeff
Yes. The front where the pan mates to the timing chain cover is much thicker on one, but I can't remember the changeover year. If you get the 4 piece design you will get both the thin and thick segment.
Old Aug 11, 2008 | 02:08 PM
TedH's Avatar
TedH
I opted for the Fel-Pro one-piece (blue) seal and never had another problem with oil leaks. Before, I'd keep dropping the sections of the 4-piece gasket. Now, with the blue 4-corner screw-in retainers that hold the gasket in place, I am able to hange the gasket and slide the pan over the retainers and start a couple key pan bolts before removing the retainers (when you slip the pan over them, the retainers compress and keep the pan in place while you start the bolts... then you just un-screw the retainers). Makes the change an easy one. And, with the one-piece you cannot overtorque and mash the gaskets like you could before (but still need to use common sense when snugging the oil pan bolts of course).
Old Aug 11, 2008 | 03:02 PM
enkeivette's Avatar
enkeivette
I'm running a FelPro 1 piece and I have had leaks, eventhough I torqued it in the proper sequence. This is probably because I have a stroker clearanced pan and it only has half the bolt holes that a stock pan does. Point in case, it never hurts to use RTV. Silicone seals flippin everything.
Old Aug 11, 2008 | 03:47 PM
jnb5101's Avatar
jnb5101
thanks for the info. and thanks for not answering my first question!
jeff
Old Aug 11, 2008 | 09:52 PM
stingr69's Avatar
stingr69
Measure the radius at the front of the pan you want to use. If you have 2.25" you want a '74 and earlier gasket. If you measure 2.375" you need the '75 and up gasket. Most all service replacement pans regardless of the year of the original engine application will have the '75 and up gasket design.
-Mark.
Old Aug 12, 2008 | 06:41 AM
fugawi's Avatar
fugawi
felpro one piece.
To oil pan gasket
