there is a "flow control" valve and spring assembly located behind the fitting where the high pressure line goes into the rear of the pump. this is where the pressure for the system is maintained. if this assembly hangs up due to a broken spring or warn valve, it would allow fluid to circulate without building pressure. then it could shift back or rotate into position and start working for awhile.
could be your problem.
it goes from perfect power steering
to a shudder when turning while fighting the wheel like no power steering back to perfect power steering.
i hate to just start throwing parts at it but that does sound like what could be happening with pressure valve thing at the pump. is there a way to check or would it be better to just go ahead and replace the pump to start with?
It sounds like the pump to me. You can remove the power steering hose from the back of the pump. Then remove the discharge fitting on the back of the pump that the hose was attached to. You will be able to reach inside the discharge cavity and depress a flow control valve. There is a spring behind the valve and you should be able to easily move the valve against some light spring pressure.
If you obtain a new pump, you will most likely have to use your original discharge fitting and the control valve.
One tip. If you lose power assist in both directions (right turns as well as left) then your problem is in the pump. If you lose power assist in only one direction the problem is in your control valve.
I'm sure the fluid change, etc. was a "do good" move and the pump would work better...for a while. If (when) it starts having trouble again, just remove and rebuild the pump and cylinder. That is really a pretty easy job and the rebuild parts are inexpensive. If you have it done, it would probably cost you $300; if you do it yourself, it will cost you $50 and a day's work [or less].
