Flywheel size
Old Aug 13, 2008 | 12:30 AM
Bridge City's Avatar
Bridge City
Default Flywheel size
I will be installing a 383 stroker wiht at TKO 600 in my 64. What determines the flywheel size I should use? 153tooth or 168tooth?
Brian
Old Aug 13, 2008 | 12:35 AM
tigers123's Avatar
tigers123
Gen 2 383 from gm or 350 stroked out to 383? Need to know
Old Aug 13, 2008 | 07:58 AM
Bridge City
The block is a 1986 up GM 350 stroked to 383
Old Aug 13, 2008 | 10:28 AM
mopkop's Avatar
mopkop
Default flywheel
11 inch 168 tooth flywheel
Old Aug 13, 2008 | 11:46 AM
wfo76's Avatar
wfo76
Brian
Flywheel size is determined by bellhousing. Do you really have a 64? I have no idea what bellhousing a 64 uses but I think the small blocks up through 68 used the 153 tooth 12 3/4" flywheel with 10.4" clutch. The normal bellhousing with the small clutch was the 403 but don't know about C2's. In 69, most Vettes went to the 621 bellhousing, 168 tooth 14" flywheel and 11" clutch. Most 383 (400) flywheels I would think are the larger 168 tooth so you will need a 621 or equivalent bellhousing.
11 inch is the clutch size; flywheel sizes
flywheel........teeth.......clutch
12 3/4"..........153..........10.4"
14"................168..........11"
Old Aug 13, 2008 | 03:17 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
You will probably need a different bellhousing for an 11 inch clutch (168 tooth flywheel).
If your 383 requires an non-neutral balance flywheel, there are 153 tooth flywheels made with that balance - I have had a good 20 lb steel flywheel from McLeod.
Old Aug 13, 2008 | 03:20 PM
larrywalk's Avatar
larrywalk
Flywheel tooth count: 153; diameter: 14 inch.
Flywheel tooth count: 168; diameter: 12.88 inch.
Old Aug 13, 2008 | 05:48 PM
b71vette's Avatar
b71vette
I believe it's 168 tooth equals 14inch dia.
153 tooth equals 12.88inch dia.
also check the bolt holes on the block where the starter mounts, to verify it has bolt holes tapped to accommodate starters used for 153 or 168 tooth flywheel. an oem (diagonal mount) starter designed for a 168 tooth flywheel will not work with a smaller dia. flywheel and vice versa. I believe there are aftermarket starters which will work both.
Old Aug 13, 2008 | 07:19 PM
Ironcross's Avatar
Ironcross
This is backwards
Old Aug 13, 2008 | 07:32 PM
Bridge City
Thanks for the info. I will check the bellhousing size and bolt holes on the block.
Old Aug 14, 2008 | 03:34 AM
stingr69's Avatar
stingr69
'63 Corvette has a one year only setup on the bellhousing/front bearing retainer area so watch out for that. The '64 and up SBC C2 will be for the 10.5" clutch setup that uses the 153 tooth flywheel. Those are all 327's and none of them ever had a 11" clutch with the 168 tooth flywheel from the factory.
-Mark.
Old Aug 14, 2008 | 07:54 AM
Bridge City
Thanks Mark. I think I will go with the 153. I was also told if I stay with the 153 and high torque starter I will have more room for headers.
Brian
Old Aug 14, 2008 | 09:55 AM
larrywalk's Avatar
larrywalk
Oops, I did type it backwards.
The small diameter is also sometimes referred to as 12.75 inches, but my GM book says 12.88, the difference probably having to do with the mean tooth diameter versus the overall diameter.
Thanks for catching my typo.
To Flywheel size
