New restorer , usual problems
Old Aug 13, 2008 | 12:59 PM
another restorer's Avatar
another restorer
2nd Gear
Default New restorer , usual problems
Im new to this forum , hello everyone
Restoring '69 vette coupe , inserted new 383cui stroker engine
Problems:
1. looking for the right (for new chromed 85amps alternator) bracket kit
still not sure what to order since engine is new 383cui stroker (performance)
2. can't find twin part of Pillar Post Weatherstrip Retainer
(http://www.ecklers.com/product.asp?p...8&dept_id=1514)
It's weird i can't find it (ecklers.com , corvetteamerica.com) what's the name for it ? Looking for a wider twin still/chromed pillar.
3.badly need good , clear diagrams for electric and vacuum installation.
4. Does anyone know if new alternators got voltage regulators inside ?
5. Is it possible to find tachometer matching to my new engine , (stock cord based won't work )
Thanks for any info and help
Phil
Old Aug 13, 2008 | 01:25 PM
Project80's Avatar
Project80
Try this post for electrical diagrams. He just sent me a diagram for my 1980 (thanks again). Just PM him with your year.
http://forums.corvetteforum.com/show...light=papawana
Old Aug 13, 2008 | 02:06 PM
Durango_Boy's Avatar
Durango_Boy
Problems:
Phil
For a good book with wiring diagrams, get a Wilcox '69 AIM PDF on a CD. You can zoom in and search, and it's year specific to your car.
http://willcoxcorvette.com/product_i...ducts_id=25488
Yes, SI and CS alternators are internally regulated.
It's easier to get an HEI distributor with a tach cable port, so you can use your stock tachometer, than it is to retrofit an HEI tach into your car to match the HEI. A few of the vendors sell the HEI distributors with a modified shaft that has the tach cable port. Not cheap, but they are worth it.
Old Aug 13, 2008 | 03:00 PM
another restorer
2nd Gear
Default thanks so far
Thanks for your prompt help so far guys
Did u mean this by any chance (tacho,distributor solution):
http://www.ecklers.com/product.asp?p...8&dept_id=1283
or
http://www.ecklers.com/product.asp?p...5&dept_id=1285
Can't afford any mistakes in ordering , im based in Poland
Also u sure that alt. includes regulator ?:
http://www.ecklers.com/product.asp?p...3&dept_id=1196
Couse can't find stock v.regulator anywhere
Also a big problem with bracket set for this alt. , have to install it on right side of the engine , won't fit it on the left over PS pump.
Sorry for beeing green , but it's my first vette , and im outta good instructions/diagrams/experience
Thanks for your help again
Neat superman avatar by the way
Old Aug 13, 2008 | 03:39 PM
71rdster's Avatar
71rdster
If you are talking about the windshield side reveal molding or windshield side frame, that wraps around the pillar, Ecklers carries a reproduction, but does not show any in stock. Paragon reproductions only shows used. Forum sponsor Willcox appears to have them as does Corvette Central.
http://www.parts123.com/parts123/yb....Z5Z5Z50000050G
Hope this helps. Welcome to the forum and good luck.
Old Aug 13, 2008 | 03:42 PM
PETKAH's Avatar
PETKAH
You can find a good HEI tach drive for under $200. Get an alternator from PEPBOYS/etc.
Old Aug 13, 2008 | 03:43 PM
PETKAH's Avatar
PETKAH
Sorry - didn't realize you are in Poland. But, you can still get good parts less expensive than some catalog companies.
To New restorer , usual problems
