Halp! How bad is this?
Old Aug 13, 2008 | 02:40 PM
Buffalo Dude's Avatar
Buffalo Dude
St. Jude Donor '07
Default Halp! How bad is this?
So I'm regreasing the suspension, working on the driver lower ball joint, when I start thinking "Hmm, I seem to be putting in quite a bit of grease. I'd better stop now before I break something." Sure enough,
The boot is split, but now I know it's well greased :o
How bad is this? Do I need to get it replaced right away?
Old Aug 13, 2008 | 03:08 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
You're in no immediate danger. Clean off the excess grease and then wrap the boot with several turns of black electrician's tape until you can replace the boot.
Old Aug 13, 2008 | 03:15 PM
V-Twin's Avatar
V-Twin
your wheel will fall off immediately
Seriously, you can clean out most of the grease and clean the split rubber with some brake cleaner and use super glue to repair the split, this will seal the boot till you have time to change it sometime soon
Old Aug 13, 2008 | 06:23 PM
Buffalo Dude
St. Jude Donor '07
Rip is too big to tape up
Old Aug 13, 2008 | 07:32 PM
7T1vette's Avatar
7T1vette
Clean off the outside of the boot well (remove all grease) and seal the rupture with some marine grade silicone.
Old Aug 13, 2008 | 08:45 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Wow, right by the book guys
Clean it off and forgeddabodit
Old Aug 13, 2008 | 11:57 PM
KTKelly's Avatar
KTKelly
Duck tape...
Old Aug 14, 2008 | 07:13 AM
AimHigh's Avatar
AimHigh
AGHHHHHHH!
super glue or silicone as stated above.....it ain't going nowhere!!!
To Halp! How bad is this?
