Need a little help, the stock power locks on my 82 will lock when I press the power lock button on either driver or passenger side, but will not unlock when I press the power lock buttons upwards to unlock on either side. Any idea as to how to fix this problem?
Check the grounds in the passenger door.The problem is usually one of the switches.
Had a similar problem on my 78SA. I could try and jiggle the lock bezel and it would work for a time or two. Pulled the door panel to get to the lock switch and found this.....
Cleaned all the contacts with a razor knife and made sure the connectors were clean and tight. They've worked great since.
