What ring on my trw Pistons ??
Old Aug 17, 2008 | 04:01 AM
lolo3198's Avatar
lolo3198
Default What ring on my trw Pistons ??
Hello,
I rebuild my Sb 350 and i want to change my ring kit the pistons are TRW 336744 and the cylinders of my block are in original size (4")
What brand of ring is verry good ??
What model is ok for my piston ??
Thanks,
Laurent
Old Aug 17, 2008 | 05:55 AM
cottoneg's Avatar
cottoneg
There is a very good technical Specialist at Summit. His name is Norm and he is at extension 6652 or RKoval@SummitRacing.com. The guy is knowledgeable and helped me match my piston and rings.
Old Aug 17, 2008 | 06:55 AM
lolo3198's Avatar
lolo3198
thanks for the mail adress
Old Aug 20, 2008 | 06:03 AM
lolo3198's Avatar
lolo3198
Summit have no aswer at my question
they don't find this numbers of piston
Old Aug 20, 2008 | 07:21 AM
TimAT's Avatar
TimAT
GM used lots of different pistons. That number sounds like a GM casting number. Most aftermarket TRW pistons are marked "LFxxx" or something like that. You know the diameter, you also need to know how thick the rings are. I'd go with a cast or moly ring unless your bores are like new.
To What ring on my trw Pistons ??
