512 is a 1969 block, either 2 bolt or 4 bolt. 4 bolt blocks were for the L71 solid lifter engines. The only full floating rod engines were the L88`s, ZL1, and 302 Z28 Camaros. All the rest were pressed pins or rods. Camshaft is the same grind as a L72 which is a solid cam near .520 lift both intake and exhaust. The correct crank is forged as are the 11-1 pistons. Red line is naturally with the solid cam at 6500 rpm...
I'd get a really good picture of the engine VIN pad and post it in the C2 and C3 sections.
Use a title that asks for pad validation help.
We love looking at pads...
Look at the treaded passages above the oil filter mount. I fthey are large ports (I believe) 1/4 and 1/2 pipe thread then it was a original 4 bolt block.
My hole sizing is probably wrong.
2 bolt blocks had smaller threaded ports
