What is currently wrong with your Vette?
Old Jan 2, 2002 | 05:30 PM
SteveG75's Avatar
SteveG75
Default Re: What is currently wrong with your Vette? (jvm)
1. Body cracks (always make sure jackstand is clear before dropping car back down :sad: )
2. Weather stripping
3. Paint
4. Soft top (GM says don't operate when cold. They're right, the top will start to split. :cry )
Engine drivetrain should be done this winter. Slowly coming together.
Old Jan 2, 2002 | 05:31 PM
1Bad69's Avatar
1Bad69
Default Re: What is currently wrong with your Vette? (Mikes80L48)
shims fell out from left trailing arm(car points left when you hammer it)
runs a little hot
play on the left half shaft into the housing
holley needs to be set up properly
is sitting in the garage and cant drive it
Old Jan 2, 2002 | 05:48 PM
74Vetteski's Avatar
74Vetteski
I don't want my vette to read this and get ideas. I thought I had work to do... :lol:
Old Jan 2, 2002 | 05:54 PM
Jenny's Avatar
Jenny
Default Re: What is currently wrong with your Vette? (74Vetteski)
1. Carb still off
2. Loose rocker
3. Brakes still not a-ok
4. new rear spring
5. Driver keyhole doesn't unlock anymore
6. Paint
7. INterior
8. A shop disconnected my water temp sensor... :rolleyes:
9. Reupholstered seats
that's all i can think of right now.
Old Jan 2, 2002 | 06:17 PM
Chris@VetteFinders's Avatar
Chris@VetteFinders
Platinum Supporting Dealership
Default Re: What is currently wrong with your Vette? (Jenny)
Minor stuff:
1.Window alignment
2.very small trans leak
3.fuel gauge swings 1/4 tank back and forth
4.heater water shutoff valve doesn't want to let heat IN when controls are turned to HEAT
5.some minor cosmetic stuff.
Oh yeah:
6. Brand new coolant overflow tank leaks.
[Modified by Rhys, 5:19 PM 1/2/2002]
Old Jan 2, 2002 | 06:31 PM
1yy07's Avatar
1yy07
waiting on new dash pad :chevy :mad
Old Jan 2, 2002 | 06:35 PM
dlw's Avatar
dlw
ME! (can you say "mechanically challenged")
:D
Old Jan 2, 2002 | 06:49 PM
bence13_33's Avatar
bence13_33
Hmmmm, my 'Vette still has a 350 in it....that's what's wrong with it :D . Other than that:
- (2) Broken Door Sensor Switches (My Door Ajar Light Is On All The Time)
- A Few Misc. Rock Chips Need Touched Up
- My Tail Light Lenses Are Cracking
- My Windshield Is Sparkly And It Really Makes Me :mad
Old Jan 2, 2002 | 06:52 PM
68350hp's Avatar
68350hp
the '68
1. doesn't run
2. needs paint
3. needs fiberglass repair
4. furry seat covers :U
5.spring is disintegrating
the '74
Needs rear spring
[Modified by 68350hp, 5:54 PM 1/2/2002]
Old Jan 2, 2002 | 07:01 PM
Jester69Stingray's Avatar
Jester69Stingray
Default Re: What is currently wrong with your Vette? (68350hp)
Theres no engine in it (should be back in the car this month)
Paint
needs alignment
passenger seat torn
Headlights point in random directions
clock doesn't work
Old Jan 2, 2002 | 07:06 PM
79MakoL82's Avatar
79MakoL82
Default Re: What is currently wrong with your Vette? (Jester69Stingray)
I don't EVEN wan't to think about it :cry
Old Jan 2, 2002 | 07:57 PM
ODennis's Avatar
ODennis
Over 5 years ago I took my 1982 Collector Edition off the streets. It has been a dedicated drag race car ever since. The car only weighs 2800 lbs.!!! Nothing is really wrong with it, it just isn't fast enough (yet)! :rolleyes:
I've removed many, many parts off this car (between 24K and 32K miles) and I would like to sell them. By the looks of the loooong lists in this thread.....maybe one or more of you need something I have in my basement.
Please go to the following C3 Parts For Sale forum link to see how I put my car on a diet (and maybe buy something)!
http://forums.corvetteforum.com/zerothread?id=209403
Thanks for your help and good luck with your projects!
Old Jan 2, 2002 | 08:29 PM
  #33
Scott78's Avatar
Scott78
Default Re: What is currently wrong with your Vette? (ODennis)
Well it's winter and my list is;
1. A-arm bushings( all stripped out just painted them today waiting for front end kit)
2. Side yokes
3. Trailing arm shims are about gone
4. A/C (parts on order, with frontend kit)
5. Radiator support (with the other order)
6. Leaks, you name the fluid and I'll show you the spot :D (except brake did that this summer)
I need to remember to give my UPS lady some little gift :lol:
Scott
Old Jan 2, 2002 | 09:04 PM
  #34
shawn_cake's Avatar
shawn_cake
Not enough power!
Old Jan 2, 2002 | 09:14 PM
  #35
Mike69@ECS's Avatar
0Mike69@ECS
Former Vendor
Cruise-In III Veteran
Cruise-In V Veteran
More than I care to admit!
:eek: :D
Old Jan 2, 2002 | 09:50 PM
  #36
MIKER's Avatar
MIKER
I'm just missing a few parts!
The transmission is being rebuilt
Changed ring and pinion
Changing rear wheel bearings on the passenger side
Rebuilding brake calipers
Installing new adjustable strut rods
Loads of other stuff needs to be done but I've bit off enough for now.
Old Jan 3, 2002 | 12:11 AM
  #37
Golden80's Avatar
Golden80
Here's my list:
1. Front bumper is out of alignment and has nicks in the paint from when I had a diabetic reaction and passed out behind the wheel and ran into a parked car.
2. Fast-idle sticking. (Had the car power-brake itself through an intersection today on a sandy road.)
3. Power-steering leak. (I'm becoming He-Man!)
4. Slow power windows.
5. Power door lock on passenger side sticks sometimes.
6. Leaking T-tops. (Don't they all?)
7. Cracked T-top.
8. Strange wire under the hood that's not connected to anything. :smash:
9. AC needs to be recharged.
10. One muffler hanging because I lost the J hook.
11. Both doors mildly out of alignment.
12. Left blinker not working.
13. 305ci LG4 stock motor. (Nuff said.)
(Only took me 2 minutes to think of more!)
14. Clock doesn't work.
15. Headlights need a helping hand to get up.
16. There's a gap of air in the brake lines that keeps my brake light on all the time.
17. Getting a small hesitation off the line. (My fault of course...this is what happens when you learn how to work on a QJet with no prior knowledge.)
On the ride home I also remembered:
18. Oil pan smashed in from previous owner probably hitting a curb or median. Has a slow but steady leak from the drain plug because the dent goes into a "V" right in front of the plug.
19. In cold weather it has a bog.
Hmmm...that's all I can think of right now...I'll remember other stuff later on.
You'd think my car was a real POS from all the stuff I listed...but it still looks and runs good!
[Modified by Golden80, 9:15 PM 1/2/2002]
[Modified by Golden80, 11:12 PM 1/2/2002]
To What is currently wrong with your Vette?
Old Jan 3, 2002 | 12:20 AM
  #38
79er's Avatar
79er
Default Re: What is currently wrong with your Vette? (Golden80)
1.Torque Converter needs replaced
2. 1 cat has something rattling in side of it.
Old Jan 3, 2002 | 01:23 AM
  #39
Dwayne 76's Avatar
Dwayne 76
Need to figure out where the short is in my heating controls. Thats about it.
:cheers:
Old Jan 3, 2002 | 01:39 AM
  #40
redc3vette1's Avatar
redc3vette1
Default Re: What is currently wrong with your Vette? (MikeC)
Don't get me started, the list is too long!
and its getting longer by the day for me :cheers: :cheers:
