Trip odometer cable
Old Aug 18, 2008 | 11:10 AM
tristan69's Avatar
tristan69
Default Trip odometer cable
I just changed my speedo, tach cable and gauge lenses as the dials were all over the map and lenses looked bad.
I noticed that my Trip odometer cable does not turn after the reinstall.
I can't remember if it moved before I did the cable changes.
Maybe I kinked the wire, but my question is if I leave this and drive for now will it damage the gears in the tach or odometer, or anything else?
I would rather leave this for a winter fix as I am prepping for new paint now.
Old Aug 18, 2008 | 02:01 PM
wattac2's Avatar
wattac2
Does the **** still press in and out? If it's stuck in then it's still engaged with the odometer gears and may harm them. If it's out and the odometer is turning, then all is fine, you just won't be able to reset the odometer.
Old Aug 18, 2008 | 08:53 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Wattac2 is correct,
If you can push in on the cable and reset the trip odometer, the cable is fine. If it is stuck pushed inward, you can damage the drive gear inside the speedometer.
What will happen is this: The trip odometer is driven by another 1:1 ratio gear in direct relation to the odometer. If the cable is stuck inward, this will lock up the trip odometer and cause the gear that drives it to bind when the odometer turns over.
If you just forgot to push upwards and then turn then nothing is wrong.
Willcox Inc.
Old Aug 19, 2008 | 02:43 AM
tristan69's Avatar
tristan69
Originally Posted by Willcox Corvette
Wattac2 is correct,
Willcox Inc.
I cant push it in or pull it out or turn it. It is stuck where it is.
So I guess what your saying is that I have to disconect before I drive.
Does this sound like a kink that would fix by just rereuting it or do I have to try and get my hand in there to take it off the odometer and replace?
Thanks again
Old Aug 19, 2008 | 09:26 AM
0Willcox Corvette
Former Vendor
Try taking the nut off the end of the cable, and then push the cable back through the retaining brace. This may relieve the pinch.
If this fails, you may try un-screwing the cable from the back of the cluster housing. It is real hard to reach and I advise you to use a wrench on the adapter nut made in the housing. This is the part the cable screws in and if you strip it out of the housing you will create a mess. The end of the cable that screws in to the housing also has a nut on it, so you will need two wrenches to remove the cable.
Willcox
To Trip odometer cable
