cam install
That was my first mod over seven years ago. I bought "How to Rebuild your Chevy Smallblock" and started tearing the engine down. Pretty straight forward job.
then reassemble and setup your rockers along with a whole bunch of other stuff, while leaning over your car ?
Man that makes my Back hurt just thinking about it !
these cars are like looking down into a hole their so low.
I know it can be done, but I would consider the miles on the motor.
and consider pulling the motor, with possible going thu whole motor.
if you only do rings and bearings, the cost is min.
building a motor on a stand is fun and comfortable,
rebuilding a motor in a Vette is Not.
of course if somebody else is doing the actual work, no problem !
good Luck.... 69VETTE
...and the condenser, IF you have A/C.
