Feeling stupid...
Old Aug 21, 2008 | 05:48 PM
h2ohouse's Avatar
h2ohouse
Default Feeling stupid...
Put 235/70/15 (indy firehawks) on my 68 all around. looked great got in to pull out of the station and heard snap..crackle...crunch. Why didnt I just turn the wheel first to see.....
They are ordering 235/60's for the front now...I think I will have them get 4 all around so I can rotate. They checked the demensions and said they are smaller than the 225/70's that came off...
I almost cried....due to my own ignorance!!!
I put this in the tech section to see if the sizes that were suggested would work .
Thanks,
Jeff
Old Aug 21, 2008 | 05:55 PM
Durango_Boy's Avatar
Durango_Boy
Aren't shops supposed to test drive cars they put new tires on to check for things like that? As far as I'm concerned they are responsible for any damage, and should take the old tires back free.
Old Aug 21, 2008 | 06:07 PM
nutsy's Avatar
nutsy
what damage did it do? did you crack fender?
Old Aug 21, 2008 | 06:09 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
235/70/15 is very close to orginal size ??
how does smaller size tire create a problem ??
Old Aug 21, 2008 | 06:26 PM
thegazman's Avatar
thegazman
Default thegazman
Your original tires 225/70/15 is: 27.4" diameter
235/70/15 is: 28" diameter
235/60/15 is: 26" diameter
255/60/15 is 17.1" in diameter and was an option on many C-3 from the factory. This size came on my 79 L-82. I don't know if they will fit your 68 or not.
Old Aug 21, 2008 | 09:31 PM
h2ohouse's Avatar
h2ohouse
I take full responsability...I thought I had done my home work and told them what size I wanted. I would have normally changed my own, but did not have the time. I should have just turned the wheel before driving.
Damage is about a 4" rip behind the pass side tire about 3" from the bottom. Not that bad just mad at myself for not checking first.
235/70/15 is 6 tenth of an inch bigger......
I will go with the 235/60 on all four....255/60/15 seems a little too low.
I will talk with the shop at least I should get the 4 new ones mounted and balanced for free....
Thanks,
Jeff
KTKelly's Avatar
KTKelly
I hope you meant that a 255/60/15 is 27" in diameter.....
Old Aug 21, 2008 | 10:26 PM
howarsc's Avatar
howarsc
I have 255-60 on rear and 235-60 on front of my 68.
275-50 drag radials for play time.
Old Aug 21, 2008 | 11:04 PM
jdunne's Avatar
jdunne
Check your wheels first;if original,on a 68 they are 7" all the later c3 are 8"...john
Old Aug 22, 2008 | 02:14 AM
7T1vette's Avatar
7T1vette
With that narrow a wheel, you might pop a bead out during a hard turn.
Old Aug 22, 2008 | 03:23 AM
RunningMan373's Avatar
RunningMan373
Do you have any pics of that setup? I was wanting to go with Firestones, but they only make 235s and 255s. C.
Old Aug 22, 2008 | 06:35 AM
gbvette62's Avatar
gbvette62
The original tire on the 68 (and 69-72's) was a F70x15, which actually is comparable to a P215/70R15. The P225/70R15 corresponds to the GR70's as found on 73-78's. In 78 Chevy switched to the metric P225/70R15 and offered the P255/60R15 as an option.
Old Aug 22, 2008 | 08:18 AM
69Vett's Avatar
69Vett
I see, the size difference now, I went with 235x 60 x16,
thats about 26.5 Dia. on all 4 tires, they look good.
but I don't have my body on yet !
good luck !... 69VETT
Old Aug 22, 2008 | 08:55 AM
thegazman's Avatar
thegazman
Default thegazman
Yes....I meant 27.1". Boy, that would be wild with a 17" tire. Talk about low profile!! However, 235's will be lower than 255's.
Old Aug 22, 2008 | 09:15 AM
TERRY CLARK's Avatar
TERRY CLARK
I thought the 235 & 255 was the same height, but different widths. The 70/60 was the sidewall height!
Old Aug 22, 2008 | 11:13 AM
thegazman's Avatar
thegazman
Default thegazman
I obtained these tires diameters from specs listed on "Tire Rack". I assume they are correct.
Old Aug 22, 2008 | 02:22 PM
Jay-Dog's Avatar
Jay-Dog
60 is relative to the width. 60% of the width. So 255 vs. 235 is 20 millimeters wider. That works out to about 12 millimeters taller at each sidewall or 14 millimeters overall height. Each mfg has different ways of measuring. Not all tires are equal.
Old Aug 22, 2008 | 03:51 PM
LoneStar26047's Avatar
LoneStar26047
Tire Sizes and Dimensions Chart from BFGoodrich. Hope it helps.
http://www.bfgoodrichtires.com/specs/radial-t-a/12.html
Old Aug 22, 2008 | 05:40 PM
thegazman's Avatar
thegazman
Default thegazman
True.."not all tires are equal"; however I was quoting diameter sizes from Firehawks which Jeff (h2ohouse) said he was using.
To Feeling stupid...
