Tach.Problem!!!
Old Aug 23, 2008 | 08:07 AM
Kilroy1024's Avatar
Kilroy1024
Originally Posted by DWncchs
He said when this filter fails it damages the tach. He blames a big part of the tach failures on this filter.
Not likely.
Old Aug 23, 2008 | 10:38 AM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
If the RC filter fails, shorting the tach wire to ground, WILL kill the ignition, and therefore the tach WON'T work! But it should work again after the ignition is fixed.
I agree that there pink wire is hooked directly to the ign cap, but I have never seen a radio noise cap between the pink wire and the cap. Quite possible, the wiring diagram is incorrect. Further, the radio noise capacitor is a simple capacitor and is not like the RC network shown for the tach filter: http://forums.corvetteforum.com/show...lter+off+broke, some 5 posts in.
In any event, the ignition is the most significant source of noise. It makes sense to have a tach filter in the line from the tach terminal on the dist cap to the tach wire.
Old Aug 23, 2008 | 10:55 AM
Kilroy1024's Avatar
Kilroy1024
There are two ways to deal with noise.
1) Try and filter it out once its been generated (inline RC filter)
2) Stop it from being generated in the first place.
(decoupling cap in post 9)
The diagram is O.K.
Old Aug 23, 2008 | 11:45 AM
...Roger...'s Avatar
...Roger...
The diagram is O.K.
So your saying that hooking it up like the drawing in post 9 is the best way?
Old Aug 23, 2008 | 01:08 PM
sly vette's Avatar
sly vette
Originally Posted by ACECO
The tach filter is located on the drivers side back of the intake manifold as per the circled area below
I doubt the filter is causing your bouncing needle issue, but temporarily bypass it to be sure. (plug the wire from the output side of the filter directly into the distributor) A bouncing needle is usually an issue w/the tach board, but it appears you have already changed that via swapping in a different tach. However did you have a differnet tach board, or did you swap the same board back and forth between the two different tachs?
Good Luck!
This is on a boat aplication. I have no filter currently in place.
The diagram is O.K.
I have no problem with noise on my boat. Just the bouncing needle.
Please guys refer to my original post. I have no problem with fixing any other problems in this thread...I just want my tach to read steady on my boat.
Mark
Mark
Old Aug 23, 2008 | 01:23 PM
mrvette's Avatar
mrvette
Sly, check your email.....
Old Aug 23, 2008 | 02:59 PM
Kilroy1024's Avatar
Kilroy1024
Mark
Mark
Yes, we have digressed.....
From your description, my understanding is that your tach is sort of
working, but that it bounces when the engine is at low speed.
This could be due to ripples on the 12V supply which smooth out when the engine is at high RPM.
These tachs are often susceptable to fluctations on the 12V supply.
I would try putting a 100uF/63V cap across the power lines on the back of the tach.
N.B. Watch the polarity as Caps of this size will blow up if connected backwards.
Old Aug 23, 2008 | 03:07 PM
Kilroy1024's Avatar
Kilroy1024
Both ways will result in a decrease in emmisions.
However, RF is funny stuff and the only way to determine the 'best' way is to actually measure the radiated emissions with and without the capacitor.
That being said, my bet would be that cap on the ignition coil would do a better job than the RC filter.
The RC filter will reduce the noise on the tach signal line (the wht wire in diagram 8A-14).
It doesn't really address the noise generated between the battery and the distributor (the pink wire).
Old Aug 23, 2008 | 04:43 PM
RunningMan373's Avatar
RunningMan373
Tach could be reading spikey alternator noise,,, other then installing a 50V 1000uF cap on the back of the tach (Radio shack), I would check the 2 main ground straps in the vehicle, if they were corroded, not making good contact, or if any of the alternator + wiring was not making good contact, it would generate spikes. I would inspect and clean both my main ground cable contact points and the Alternator + power wire contacts. C.
