Help Please!
Old Aug 23, 2008 | 01:56 PM
hardworkinman's Avatar
hardworkinman
hardworkinman
Default Help Please!
I am selling an intake manifold that was numbers correct for a 79 and 80 L82 engine (14007378). I was asked the following question.
"Will this intake manifold work on an L48 350 76 engine?"
can someone help me out on this one? I know it will fit the engine, but will he have to make any mods?
thanks
Old Aug 23, 2008 | 05:44 PM
hardworkinman
hardworkinman
anybody?
Old Aug 23, 2008 | 08:44 PM
Kenzy's Avatar
Kenzy
Yes. The '79 and '76 hoods are the same so there won't be any clearance issues.
Old Aug 23, 2008 | 10:19 PM
hardworkinman
hardworkinman
thanks, but, I didn't think the hood would be a problem anyway. My concern was that it would be a direct bolt on, which I am pretty sure it is. From a 350 to a 350, no brainer. But, I guess my guys question is, will everything else hook up correctly? If anybody knows that, I would appreciate it.
Old Aug 23, 2008 | 11:04 PM
AimHigh's Avatar
AimHigh
yep, its a direct bolt on..
Old Aug 23, 2008 | 11:15 PM
joshtried's Avatar
joshtried
St. Jude Donor '08-'09-'10
i would expect that you would have some performance lost.. but otherwise, should but up
Old Aug 24, 2008 | 06:23 AM
stingr69's Avatar
stingr69
The choke provision may be a concern. The '80 uses an electric choke and the '76 has I believe a divorced choke.
-Mark.
Old Aug 24, 2008 | 08:03 AM
hardworkinman
hardworkinman
I don't understand why you would loose any performance. His engine I believe only produced about 190 hp, unless they were different for that year. The L82 was a 225hp engine. If anything, shouldn't it help? The choke was a concern but I guess if he bids on it and buys it, he'll just have to work that out. Thanks
Old Aug 24, 2008 | 08:20 AM
rclinton's Avatar
rclinton
Veteran: Marine Corps
The 80 L82 intake is aluminum and flows better than the L48 boat anchor. In fact with a little port matching it doesnt flow much less than a few after market intakes. Certainly wont hurt a stock L48 engine. Even if the choke has to be switched over to the 80 electric thats a quick and inexpensive swap. JUst my .02
Old Aug 24, 2008 | 08:38 AM
'75's Avatar
'75
ttt
Old Aug 24, 2008 | 02:17 PM
hardworkinman
hardworkinman
thanks all you guys. Man, some of you have some GREAT avatars. I like it, I like it......
To Help Please!
