Need headlight help
Not just a little bit. It actually opens all the way and locks in position. I've tried adjusting the little 1/4 20 stop screw underneath, but it hasn't helped. The only things I havn't replaced are the two vacuum relays coming out of the firewall and the headlight switch itself. I'm leaning toward those two relays and praying it's not the light switch itself. Any help or suggestions would be appreciated as I'm out of ideas and wondering if I'm missing something simple. Thanks,Kenny
Then I squeezed the hose going from the tank up front to the two check valves at the firewall, shut the engine off, and both lights open in locked position.
The hoses at the check valves at the firewall may be connected wrong. I need to look at a diagram.
The only way I can get it to work correctly is if I turn the light switch off with the engine running, let the drivers side close, then shut the motor off when the passenger side is almost closed. After the motor stops, the drivers side will burp and raise up about two inches, then it stays closed. If I turn the lights off and let the motor keep running for any length of time, then shut it off, that's when the light pops back up. Does that tell you anything? When I said in my original post that the only thing I hadn't replaced was the relays, I meant to say the vacuum check valves at the firewall. The relays up front between the actuators are brand new, as well as the actuators.
KC
