Best method to install crank gear
Old Aug 24, 2008 | 06:40 PM
VettAgra's Avatar
VettAgra
Default Best method to install crank gear
I'm installing a new timming chain and need a good method to install crank gear. I really dont want to beat it on with a hammer if I can get away with it. I though about heating it with a propane torch but wasnt sure if that would damage it in any way, or if it would even help.
Thanks, Kevin
Old Aug 24, 2008 | 06:55 PM
Durango_Boy's Avatar
Durango_Boy
Three ways come to mind.
Do you have an oven close by? Simply heat the gear to 250 or so, grab it with some locking pliers or a thick oven mitt, and QUICK before it cools, slid it on to the crank and it should seat perfectly and cool in place.
If you can find one, a short length of heavy pipe that'll fit over the snout of the crank would be fine. Use the pipe and a mini sledge to hammer it on until it seats against the shoulder.
If you're timid and don't want to run through the house with a very hot gear in your hands, and you don't have a large diameter pipe and a mini sledge, you can slide in on the snout, and slowly tap it on with a hammer and rod. I usually do it like a clock, striking it at 12, then 1, 2 ,3, and so on all the way around over and over again until it's seated. Every time you punch it, not super heavy, but a firm tap, it'll slide just a bit further on.
Old Aug 24, 2008 | 07:00 PM
VettAgra's Avatar
VettAgra
Thanks for all your help Durango_Boy.
Old Aug 24, 2008 | 07:03 PM
Durango_Boy
You're very welcome.
Old Aug 24, 2008 | 08:57 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I used a CompCams crank gear installer. Used with my harmonic balancer installer it really makes it easy. Oh yes I have allot of tools
http://www.jegs.com/i/Comp%20Cams/249/4789/10002/-1
Old Aug 25, 2008 | 09:09 AM
FB007's Avatar
FB007
This is the best way.
Heating in an oven, or using a propane torch is also fine.
NEVER use a hammer. The babbit thrust bearing is EASILY damaged this way.
Old Aug 25, 2008 | 07:58 PM
tigers123's Avatar
tigers123
Only if you want to break the thrust flange off the rear main. Not a good idea. Go to autozone and rent the installation tool or buy one.
Old Aug 25, 2008 | 09:56 PM
Durango_Boy
Have you ever seen a case where this happened? I'm just curious. I know in theory, if you whale on it you'll harm something, but the gear is not that hard to get on...not like a balancer, and a few quick taps and it's on good and solid. Almost everyone I know uses this method...I use the oven method because it's close...but I don't know of one single case where the main bearings were damaged when a hammer was carefully used.
Old Aug 25, 2008 | 11:26 PM
FB007's Avatar
FB007
If you know hammering can cause harm, why suggest it?
It's the same to me as suggesting someone install a bad fitting windshield with a jack hammer.
Even if it did not crack, babbit is soft, and you could probably measure the compression with a feeler gauge.
The OP asked the BEST way to install it. Pounding on an installed crank is the WORST way.
Old Aug 25, 2008 | 11:52 PM
Rockn-Roll's Avatar
Rockn-Roll
Uhm...the "best" way to install the crank gear is to take it nice and easy...line it up properly and press it onto the crankshaft. Some genius drilled and tapped the crankshaft so a bolt can fit into it...it's simply amazing...you find a bolt that is long enough to get started with the gear lined up and start torquing down on it...keep the crankshaft from spinning with whatever means you have (make sure you don't damage it!). It doesn't take much more than like 45ftlbs to get it started...it gets easier when the gear is partly on.
Old Aug 26, 2008 | 12:00 AM
tigers123's Avatar
tigers123
I have seen them cracked because of that. What do you suppose that does for somebody using a clutch set up in their car? They will finish off the thrust main first time they lay some rubber. Also if you crack or bend the the thrust main you changed the tolerance on the crankshaft travel. Which has a really big effect on everything attached to that crankshaft. Why do you suppose they make the tool? Reason it out, it is not a good idea. You won't find that going on at a major engine builders facility. There is a tolerance for main bearing end thrust. Look it up and get back to me and tell me what it is.
Old Aug 26, 2008 | 12:07 AM
tigers123's Avatar
tigers123
Default food for thought
http://www.chevyhiperformance.com/te...nce/index.html
Old Aug 26, 2008 | 12:17 AM
dstaley's Avatar
dstaley
I haven't seen thrust bearings damaged this way nearly as often as I've seen crankshafts bent or broken this way.
I use the Moroso tool. It's basically the same thing as the Comp Cams tool. It's the right way to do the job, and in the long run it's the easiest.
Old Aug 26, 2008 | 12:40 AM
Ironcross's Avatar
Ironcross
On old shafts, its best to de-bur them and the gear almost falls on with a few taps using a brass drift and hammer. But a BFH is not necessary..
Old Aug 26, 2008 | 12:50 AM
400hp427vette's Avatar
400hp427vette
St. Jude Donor '09
I say save the money and hammer away, J/K. Heating like DB says and using the tool is the best way IMO
Old Aug 26, 2008 | 09:29 AM
fauxrs2's Avatar
fauxrs2
before I owned the proper tool I used a short length of Wooden dowel and a light hammer...the wooden dowel is softer than the bearing.
there is no need for a Sledgehammer, which implies (but wasnt DB's intention im sure) wailing away on it like we are making a horseshoe, the gear will walk on just fine with light rapping. that kind of rapping isnt going to do any kind of damage to the thrust surface of the bearing.
all that said, get the tool and do it right... its not like its all that expensive.
Old Aug 26, 2008 | 09:46 AM
Durango_Boy
You're correct that's not what I meant. I feel I have greater control using a mini sledge. Much slower and smaller taps and it's more even and concentrated. I usually used a long brass drift if I couldn't find the pipe, and it taps on very easily.
Lets be clear, there are lots of uses for a hammer on a Vette, and swinging it hard enough will damage ANYTHING. However, using it correctly with the right touch will accomplish a lot of things without damaging anything.
To Best method to install crank gear
Old Aug 26, 2008 | 10:47 AM
Solid LT1's Avatar
Solid LT1
Like Durango Boy first said, heat that gear up to 275 degrees or so and it will slide right on, I use a hot plate for that purpose along with a pair of MIG welding gloves.
Old Aug 26, 2008 | 05:35 PM
VettAgra's Avatar
VettAgra
Sorry about all the problems this question caused. I thought this thread was done. I have had the gear on for a couple days.
Durango_Boy, I took your advice and heated it. I may not have got it hot enough so I got it most of the way on. I beat it on with a BFH the rest of the way. May have slightly chipped a tooth but I think it is ok. Still better than the factory one. Just kidding, I did "tap" it the rest of the way with a hammer and a piece of pine.
Thanks for all the info, Kevin
Old Aug 26, 2008 | 07:20 PM
markdtn's Avatar
markdtn
Cool the crank if you can to shrink it; wrap the snout in cold towels or stick the crank in the freezer if it is out. Heat the gear in the oven or in a pan of hot water on a hot plate right next to the car. Put it on using welding gloves. If you are fast enough it will go all the way.
