Timing chain selection/replacement
Old Aug 26, 2008 | 03:13 PM
2kbluer6's Avatar
2kbluer6
Default Timing chain selection/replacement
I've got my engine out of the car and plan to change the bearings, oil pump, and timing chain (Long story). Everything is stock (427/390). So far, I'm planning on Clevite 77s for the bearings and stock for the oil pump. However, I'm still a little bit unsure about the timing chain. Somebody recommended the Cloyes true roller. Will this even work with this stock motor or should I go with the single non-roller type. I'm not looking for super high performance, just something that will work well for my engine.
Old Aug 26, 2008 | 03:51 PM
DRIVESHAFT's Avatar
DRIVESHAFT
The true roller is unneeded.
If you want to us it, it will be fine.
If you just use a stock replacement, you will be fine too.
It's your choice.
Old Aug 26, 2008 | 05:04 PM
Durango_Boy's Avatar
Durango_Boy
I have been using a lot of Rollmaster double rollers and LOVE them. They are cheap on Ebay and I am really impressed with them. I think they are from Australia.
Old Aug 26, 2008 | 08:05 PM
Reggie Dunlop's Avatar
Reggie Dunlop
The Cloyes chain will fit your motor and will do the same job as the factory chain and gears did. A good quality stock replacement chain and gear set will work just fine for your stock motor.
Old Aug 26, 2008 | 08:13 PM
2kbluer6's Avatar
2kbluer6
Thanks for the suggestions. It's kind of nice to know that the cheaper part will do just fine.
To Timing chain selection/replacement
