The beast lives !!
Anyway I will post a video but it was too late tonight to start revving it up. Also have to the hydroboost brakes working before I can take it for a spin, I am a happy camper !
I don't drive my Vette if it is cold enough to have the windows up so I don't have a heater.
The Callies crank is 4 inch stroke, the bore diameter is 4.125"
- World Motown 400ci small block, 350 mains with splayed billet caps,
- AFR 227 Eliminators with port matched Vic jr. intake by AFR
- T&D Shaft Rockers, 1.6 ratio, Manley .080" wall pusrods and
- Comp Cam small base circle Endurex solid roller lifters
- "Classified" solid billet roller, small base circle lift .650" "ish", dur. 250 "ish"
- Callies DragonSlayer crank, 350 mains, 4 inch stroke
- Eagle stroker rods with ARP 2000 bolts
- Mahle pistons, with chromoly faced rings
- ATI Race Super Dampner
- CVR billet timing cover
- CVR mini starter
- Cloyes timing set with encapsulated torrington bearing
- Melling HV oil pump
- Milodon 7 qt oil pan
- Edelbrock Victor water pump
- Hays lightweight ( 25lbs ) billet steel flywheel
- Center Force clutch
- MSD Digital E-Curve Pro Billet distributor
- MSD Super Conductor wires
- 825 Drag Race Demon carburetor
- Hooker Super Comp header into 3in. SS mandrel bend exhaust
