LS4 into LS6
Old Aug 27, 2008 | 07:07 AM
T L Ramsey's Avatar
T L Ramsey
1st Gear
Default LS4 into LS6
Have 73 LS4, want to make it LS6. Is this possible-practical. If so HOW TO
LS4 has 17,000 miles
TL
Old Aug 27, 2008 | 08:01 AM
sxr6's Avatar
sxr6
Quite a diff between those two.
Forged crank, rods, pistons, heads, centre head, carb, cam & more if you want to duplicate the LS-6.
If you just want a good 454 making approx same HP that's much easier now days!
You need pistons to up your comp a little, you should have good enough heads, a roller cam & set-up & some quadrojet & timing tuning & you should be there.
Old Aug 29, 2008 | 07:27 PM
Iliad's Avatar
Iliad
Yes, an LS4 can be converted to LS6 specs. You need to find a machine shop that can convert a 2 bolt block (LS4) to 4 bolt main caps. You need to purchase the 5 main caps and have them alignbored to your block. Then you need to purchase the forged rotating assembly as the previous poster stated << Forged crank, rods, pistons, heads, centre head, carb, cam & more if you want to duplicate the LS-6>>. Another alternative is to purchase a complete GM crate motor such as a 502!!!
To LS4 into LS6
