Brake pedal question
Old Aug 28, 2008 | 04:30 PM
Silver 73's Avatar
Silver 73
Default Brake pedal question
I just got a '73 with a 4 speed. It had been sitting in somebodies driveway for 11 years, so to say there are some rust issue's is an understatement. I'm trying to get the brake pedal and clutch pedal assembly out. I need to replace the bushings and spring on the shaft because after you hit the brake pedal it doesn't come back all the way and the brake lights stay on. My problem is, I'm trying to remove the pin and clip that hold the master cylinder clevis onto the brake pedal. The clip came off, no problem. In my manual it shows the pin as being removable, but I'd swear it's welded in place. I've tried vice grips, hammer and chisel, and just plain beating the heck out of it. But, it will not budge. I've also drownd it in WD-40. Any suggestions??
Old Aug 28, 2008 | 04:38 PM
Durango_Boy's Avatar
Durango_Boy
You're going to just keep working on it. That pin should come right out without the clip.
Old Aug 30, 2008 | 09:32 PM
Silver 73's Avatar
Silver 73
Well, I finally got the pin loose. Now it doesn't clear the assembly that holds the brake and clutch pedal's in place. Shouldn't the pin come all the way out?
Old Aug 31, 2008 | 08:29 AM
Durango_Boy
Try pushing the brake pedal inward to get the pin out if it won't clear anything when at rest.
Old Aug 31, 2008 | 11:21 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
If moving the pedal forward doesn't do the job, you may have to loosen the nuts to the booster (or MC if you have manual brakes) to give you more flex. I had no trouble getting the pin out but had a nighmare getting it back in. Without loosening the nuts, I'm not sure I'd ever have got the pin in place.
Old Sep 7, 2008 | 08:39 PM
Silver 73's Avatar
Silver 73
I finally got it out. I just had to convince it with some vice grips. Now, I just have to clean everything up and put it all back together.
To Brake pedal question
