Hard Pull To The Right
I bought the car one year ago and the listed repairs done to her the month before I bought her were
NEW EDELBROCK CARB,
NEW VALVE COVER GASKETS,
NEW INNER AND OUTER TIE ROD ENDS,
NEW SWAY BAR BUSHINGS,
NEW MASTER CYLINDER,
4 NEW ROTORS AND BRAKE PADS,
2 NEW CALIPERS,
4 WHEEL ALIGNMENT
So if you could help me by telling me what check list you would use from this point to see what the heck is happening I would be forever (I'm old, so thats not really that long) grateful.
Thanks.
David
Same thing happened to me last year, when I took my then newly aquired baby out for her maiden voyage, after a lot of work getting her road ready. Front right caliper, too......is that a coincedence?
Anyway, you, your caliper is clamped down on your disk, causing the pull, and when you hit the brakes, it balances out because now there is equal pull to the other side.
You're gonna have to replace it, sad to say. Or, I suppose you could rebuild it, but if you are still stock, you can get the replacements at auto zone for the around the same cost as a rebuild, plus it comes with a warinty.
Honestly, though, from 20/20 hind sight, it's best to just replace all four at once. I tried to nickle and dime it, and ended up replacing all four calipers anyway, one at a time, lol. Very expensive, when compared to the fact that you can get kits with all four, aftermarket, from summit, or other places.
Good luck.
I don't mind spending the money and want it done correctly. I suspect Bubba got involved the last time this got touched!!!
Thanks again.
David
Thanks again.
David
You said you already have 2 new calipers, they are rear, correct? As I said before, I tried to nickle and dime it, and it was a huge stinking pile of fail. Just replace them all, if one is rotted, or siezing, etc, they probably all will, at some point, soon.
And do the work yourself. Calipers at autozone are around 70 bucks, if you have the core. I am pretty much not a mechanic at all, in any way, shape or form, and i was able to take the old ones off, and put the new ones on. It takes about 30 minutes per caliper, as long as you spray the crap out of the bolts all week, here and there, with wd-40.
It'll save you some cash, and, I'm not sure about where you are, but here, where I live, it's peace of mind. I don't really trust anyone, because I know to many people in this area. Fact is, they are all lazy bums. You want to find the bubba responsible for a lot of the problems on these cars, you need look no further than your local auto shop.
Just my .02 cents.
It depends on the stuff you are getting.
The calipers I got were AC Delco, direct stock replacements, same as any other shop will sell you. Difference being is, autozone's come with a warrenty.
Sure, I won't buy tools there, or other things, but for some things....
I gotta say it...
Get in the zone.
Thanks to all.
David
Thanks to all.
David
How do your break lines look? For mine, I had to replace the front lines, they were really bad, but the rear lines were ok, they looked newer.
Last, and the most hateful part...
How does your E break work? If it works, stupendois...but if not, prepare for hell, lol. Actually, if I had it all to do over again, I probably would NOT have installed the parking break kit, as it STILL doesn't really work that well. Poor design.
You want to autocross it or something, then yes, go with some after market calipers. If not, those breaks are really all you need. Mine stops on a dime, every time.
Thanks to all.
David
I guess what I'm trying to say is, analyze the problem so you know what you need before just buying a lot of parts you may not need. If you do decide to do the work yourself, speed bleeders will make the job of bleeding a lot easier.
C2/C3 brakes are really very good when set up correctly - they survived a lot of racing miles in their day. Their major drawback is weight. Nobody uses cast iron calipers nowadays.
Cheers,
Pete
30 bucks, but it's really the only "shop book" you'll need. I went with a haynes repair manual first, thinking it would pretty much do the job. And for a while, it kinda did. Then I stepped up to the chilton, but again, same problem. I bought the AIM, and have never looked back.
Thanks again.
David
One thing leads to another, it all starts with the brakes. Then, you know, get those lines. But hey, while you are under there, why not take a look at those U joints......oh, and that spring looks saggy....oh, and look at those idler arms up there....they look old and used up....and oh man oh man, look at those poor, abused rubber bushing.....
and before you know it, you're broke, your wife is POed, your kids miss you, you have oil in places that really shouldn't have it, and all in all, you couldn't be happier.
With the calipers, take the wheels off, and kinda get your head inside the wheel well, and you can see behind the calipers a little, and you will see the bolts that hold them. Spray the heck out of those, for a few days, and you will have a MUCH easier time getting them off. Also, spray the heck out of where the brake lines feed into the calipers, as they will also likely be coroded, and if your lines are in good condition, it would suck to round off that little nut/bolt thingy on them, making you have to cut the line, and replace it, like I did, lol.
Last, if your lines have to be replaced, save all of the screws and mounting clips. You will lay the new lines down in the same spot the old ones went. It's not too bad, really. Carry a piece of the old line in, so you make sure you get the same size, at whatever store you buy the new, stainless steal lines at.
Some people will tell you to go with, I think it's a DOT4 setup, or silicone, or something....but it's up for debate, really.
Cheers,
Pete
I guess a good question to ask would be, how many miles does the car have? I will assume the calipers are original....as, new these were pretty darn tough brakes. Like I said, though, if he is going to the trouble of replacing even the rubber hoses, from my limited exp, may as well replace the calipers, if they are old. It's only a matter of time and miles before he has to replace them anyway.
Seriously, if you're not into the DYI, take it to a shop. Preferably one that deals with Vette's. It's good insurance against screwing it up yourself.
But when you APPLY the brakes it pulls to the left cause only that side is fully grabbing.
Had that problem on 2 of mine over the years. Replaced both front hoses for the cure.
Disconnect the hose from the caliper and see if you can bleed any fluid through it. Then remove the hose from the steel line and try bleeding it again.
First time it happened to me I simply worked a wire through the hose flushing it with brake cleaner til it cleared out. But just til I got new ones.
There is no fluid on the right front tire. The hose appears to be old but no dents or indented areas. I will remove the hose from the caliper and see if she bleeds. I will then remove it from the steel end and see again if it bleeds.
I need a check list of what to check first, then second, then third, etc. Anyone have such a list for this first timer?
1) Check calipers, brake pads, hoses, etc.
2) Check tie rods, bushings, etc.
3) Check springs, shocks, etc.
I can do most of this myself but I fear how much the etc. is going to cost me.
This is what the previous owner said he did to the car a month before I bought it:
NEW EDELBROCK CARB - I see it sitting on top of the Edelbrock Performer Intake Manifold
NEW VALVE COVER GASKETS - Valve covers are finned L-82 style.
NEW INNER AND OUTER TIE ROD ENDS - Yep, I see them there.
NEW SWAY BAR BUSHINGS - Yep, those are there too.
NEW MASTER CYLINDER - That explains why it is new looking.
4 NEW ROTORS AND BRAKE PADS - We will see shortly.
2 NEW CALIPERS - Yep, One Left Front, One Right rear.
4 WHEEL ALIGNMENT - Handles nicely except that nasty pull to the right when you drive her.
Thanks for your guidance.
David
[But, don't buy ANYTHING at AutoZone....that is, if you want it to 'live' very long.]
